Paint on old sailing ships. question
    April 2007
Posted by JTRACING on Saturday, July 9, 2016 9:37 PM
not being familiar with ships, I was curious what type of finish the paint was on naval ships such as the H.M.S. Bounty, Victory etc... would it be very glossy or dull in finish, and was the paint always maintained or would you find it wearing off in places?
thanks for any help
    September 2012
Posted by GMorrison on Saturday, July 9, 2016 10:37 PM
It was usually satin, not too shiny. Also there were finishes other than paint. Navy ships were pretty well maintained. When modeling a naval sailing ship, prim and proper is the way to go.
For instance, on HMS Victory, there were close to 1,000 men in the crew, as 100 guns with 9 men each, even accounting for the fact that a maximum of 50 guns or so would be fired at a time, meant that there were a lot of hands unemployed on a ship that probably took less than 100 to sail.
Idle hands are the devil's etc.
Bounty is a special case, but as Bligh was a tyrant, again well maintained I am sure.
    April 2007
Posted by JTRACING on Sunday, July 10, 2016 5:33 AM
Thank you!
    June 2014
Posted by Tanker - Builder on Sunday, July 10, 2016 9:04 AM
Hi !
    What is not known is the make-up of the paints of those eras .I would suggest you think about this carefully . Tallow and and boiled tree sap was used for wood colored places and a darker pitch like substance was used on many .The Bounty more than likely had a white lead concoction on the hull below the wales .
    This did wear off and had to be re-done to prevent the wood from being eaten up by Toredos . A very nasty salt water worm much like termites that would turn a ship spongy in about two or three years . Remember the voyages averaged two to four years minimum or more .
 In this instance they would find a good shore and " Careen " the ship , clean the growths off and re-coat the bottom .Careening was done by attaching gear to the topmasts and pulling the ship over on it's side to allow access to the bottom .
 This is why in later ships were " Coppered " or covered with a Copper infused metal and was called " Muntz metal ". The sea critters that ate wood definitely did not like those substances .      T.B.       P.S. As " G " said , the finishes would be like a satin finish if at all . Many were flat , but we are not talking twelve year old cheaply maintained ships here . Satin would be correct
    September 2012
Posted by GMorrison on Sunday, July 10, 2016 9:42 AM
HMAV Bounty was coppered after the Navy bought her.
    April 2007
Posted by JTRACING on Sunday, July 10, 2016 10:49 AM
well I'm going to be doing the old revell 1/110 bounty for my first go at ships,  I figure to just do the bottom white since its just a woodgrain molded on the model.  and the upper hull in green & black with the yellow and red accents
    August 2005
Posted by EdGrune on Sunday, July 10, 2016 11:05 AM
Another thing to remember.  At this period the crew couldn't just walk down to the paint locker and get a bucket of topside ochre.  Paints had to be mixed according to recipes.   So many pounds of white lead,  lamp black,  ground oyster shell,  and/or ochre mud to so many gallons of linseed oil.  Painting would be an all hands evolution taking a significant amount of time just to prepare the materials.    Linseed results in a flat to satin finish.   Glosses didn't come in until the shellacs & lacquers (beetles disolved in alchohol).
The white hull was probably tallow coat.   White lead in tallow (beef fat).  The lead would help cut down on sea-borne critters.
Posted by Don Stauffer on Sunday, July 10, 2016 1:09 PM
Another of those white bottom treatments (stuff) was lime in tallow- looked about the same, though.  While in olden days fleets were kept pretty shipshape in both peace and war, as fewer but bigger guns became the rule, the over-abundance of manpower shrank, and even warships began to get a bit grimey and rusty in a serious war.
On the other hand, commercial ships (other than big passenger ships) looked pretty crudy all the time.  Fun to do a commercial ship- you can really turn your weathering skills on :-)
    September 2012
Posted by GMorrison on Monday, July 11, 2016 1:56 AM
If you are building the Revell Bounty in service for the expedition (not sure what the other options are), her bottom was coppered. It's a really fine model esp. if you can find one with the figures.
Revell messed it up, not casting the hull sides with plates. Most, like John Tilley as the high bar, make the plates in one way or another. I would do them with copper tape, the Prof. in fact made up the plates.
At a minimum, I would suggest you paint the bottom copper colored.
    September 2005
Posted by warshipguy on Monday, July 11, 2016 7:57 AM
I agree with all comments so far.  The HMAV Bounty was coppered before the breadfruit expedition.  And, as with quite a few other examples, Revell got it wrong when they failed to copper the bottom, and by referring to the ship as "HMS" instead of "HMAV", the later meaning His Majesty's Armed Vessel.  John Tilley can cite other inaccuracies with the kit, which seem to be minor. I would strongly recommend that you copper the bottom using copper tape; it is inexpensive, it adheres well, and it looks good.  I would not recommend painting the hull bottom copper since the bottom shows wood grain and planking detail. It would not look right.  But, as John has said, that is up to the individual modeler.
Bill Morrison
    April 2007
Posted by JTRACING on Monday, July 11, 2016 10:34 AM
Thanks for all the input!  I went ahead and ordered a role of copper tape, hopefully 108 feet is enough lol, how many mm long is each tile? and when you get up to the water line do you leave the uneven cutoff tiles or do you run one line of tiles to clean up that edge?
    June 2014
Posted by Tanker - Builder on Monday, July 11, 2016 10:52 AM
Hi ;
 Here's a tip .Go to Hobby Town next time and get the tape used by Stained Glass Hobbyists .It works great for that and is infinitely workable .  T.B.
    September 2012
Posted by GMorrison on Monday, July 11, 2016 12:33 PM
The things were usually around 48 inches long and less than 12 inches tall.
In my limited experience, the plates are cut off at an angle at the bow and stern, without an added "belt".
    May 2003
Posted by jtilley on Monday, July 11, 2016 12:48 PM
For what it's worth, here's a link to a thread I started some years ago about my model of the Bounty
 http://cs.finescale.com/fsm/modeling_subjects/f/7/t/155394.aspx?page=1 .
To my knowledge, both "H.M.S." and "H.M.A.V." are perfectly appropriate for this particular ship. I've read a whole lot of eighteenth-century naval documents, and off the top of my head I can't recall encountering either abbreviation in manuscript form. I've seen "H.M. Ship," "H.M. Transport," "H.M. Frigate," etc. But I have the impression that the practice of attaching a three-letter abbreviation ahead of a ship's name began in the latter part of the nineteenth century. (I've never seen a contemporary reference to the Constitution as "U.S.F.," or the Victory as "H.M.S.O.L.") I wish some scholar of nautical language (Dr. John Harland, are you listening?) would do a meticulous study of this stuff. (I'm not sure I'd want to read it, but I wish it existed.)
Nowadays, "H.M.S." is used in reference to any commissioned ship of the British Royal Navy - just as "U.S.S." refers to any commissioned ship of the U.S. Navy. (William Bligh's book is titled The Mutiny On Board H.M.S Bounty. I think we can trust him.) I'm not sure any contemporary would have said "H.M.A.V.," but "H.M. Armed Vessel" was commonly written (I think).
 (I'd also like to see a study of the use, or non-use, of "the" in front of ships' names. Samuel Eliot Morison and C.S. Forester notwithstanding, I contend that the practice of omitting "the" didn't become common in nauticalspeak until well into the twentieth century.)
As for the Revell Bounty, what you think of it depends on how much you fuss over historical accuracy. When it was initially released, in 1956, it represented the state of the art, and some of its features have never been surpassed. (I love the crew figures, and the subtle shape of the ship's launch is masterful.) I won't list all the goofs in the other pieces; I took up most of them in that other thread. (Maybe the worst: the misshapen bow, the anachronistic jackstays on the yards, and the omission of the water closet at the stern.) But several other Forum members have demonstrated that it can be built into a nice, highly attractive model.
Back to the original subject of this thread: I think experienced sailing ship modelers are pretty much agreed that small-scale models are best painted with flat paint. A glossy finish has a way of looking faky and out of scale.
You've just struggled through one more of the pointless, overlong ramblings of a newly-retired Olde Phogey killing time to avoid doing anything useful.
    April 2007
Posted by JTRACING on Monday, July 11, 2016 2:42 PM
great info, thanks again!, also really awesome build you did there! I'll start a build thread as soon as i get something done on it lol.
    July 2014
Posted by Bakster on Monday, July 11, 2016 10:54 PM
JT, it is nice to see one of your projects. You put a lot of nice detail in that build. Very nicely done. I really like the look of the spars and how you furled the sails.
    September 2005
Posted by warshipguy on Tuesday, July 12, 2016 10:16 AM
Model Master has a nice line of acrylics designed primarily for railroaders that work extremely well on ships.  For example, I like their Aged White for the lower hulls of most non-coppered sailing ships.  They also have a shade of gray called Concrete that works well when painting wood decks, Burnt Umber, Burnt Sienna, Yellow Ochre, Caboose Red, among others.  Vallejo has just come out with a "Wood Effects Set" in acrylics that is intriguing. Go check them out if you have a local hobby shop.
Bill
    April 2016
Posted by Staale S on Tuesday, July 12, 2016 10:45 AM
Keep in mind that bright, clear colours (even when they were available) were basically a no-go simply due to cost. Preussian blue, for example, was something like 10 or 20 times more expensive than plain yellow ochre. Not a huge problem if you are painting a portrait but when your canvas is a ship's hull... The really good stuff, bright paint and gold leaf, might be used on small details like the royal coat-of-arms, not elsewhere.
    June 2010
Posted by Force9 on Wednesday, July 13, 2016 12:08 AM
A peripheral comment... Strangely enough, Captain Bligh (actually, I think he was only a lieutenant at the time) is not generally thought to have been a tyrant by most historians.  If anything, the mutiny might be in part attributable to the lax discipline on board the Bounty.  Bligh had a temper to be sure and was known to throw fits at those who didn't measure up (he was also a perfectionist), but his tongue lashings did not generally lead to physical lashings.  He was a disciple of Capt. Cook and preferred witholding grog and other privileges instead of resorting to the lash.  The Bounty was undersized for its mission, which led to limitations on crew.  Bligh did not ship any marines on the voyage, preferring to use valuable space for seaman.  When Christian tied up Bligh and assumed control of the ship, many (perhaps half) of the crew elected to stay with Bligh... There were more volunteers to leave with the Captain than space in the boat.  The mutiny was mostly a power grab by an underperforming subordinate and his close cohorts who wanted to return to the lusty frolics offered by the south pacific natives and not return to the rigid world of the Royal Navy.  His voyage to safety in an open boat ranks among the great feats of navigation and survival.  He later served well at Camperdown and Copehagen (under Nelson).  At Copenhagen, he knew that Nelson was ignoring the direct order to break off the battle and continued to lead a line of ships into close engagement and was praised by the great hero in his after battle report.
To Bill's underlying point, Bligh did try to run a tight ship and tried to keep the crew healthy during the long voyage and expected the Bounty to be in peak condition.
Not a perfect Captain by any means, but likely not the despotic martinet depicted by Hollywood.
    September 2012
Posted by GMorrison on Wednesday, July 13, 2016 12:45 AM
I'll stand corrected. An old school commander.
    May 2010
Posted by amphib on Wednesday, July 13, 2016 5:23 AM
Two points if I may.
First -at least- in the US Navy an officer who is given command of a ship is automatically given the honorary title of Captain even if his actual rank is Lieutenant or even Ensign.
Second the sea is not kind to ships, particularily paint. Between the salt water, wind, and sun light any gloss paint will quickly fade to dull matt flat appearance. If they were available gloss paints would have been a waste of money to apply to anything other than minor decorations.
    September 2005
Posted by warshipguy on Wednesday, July 13, 2016 7:42 AM
I wholly concur with Force9's summary.  In fact, there were many brutal Captains throughout that era; it would be interesting to compare Bligh's discipline logs with those of other Captains.  However, it should be noted that Bligh did suffer at least two mutinies, the one of the Bounty and another when he was Governor in Australia.
Bill
    May 2003
Posted by jtilley on Wednesday, July 13, 2016 9:33 AM
When I was working on my little model of the Bounty (that was almost 40 years ago - beware), I read everything about the mutiny that I could get my hands on. I think it's a fascinating study of human relations, sociology, and psychology.
Lieutenant Bligh's disciplinary statistics have been compared to the norms in the Royal Navy at the time. Bligh ordered fewer floggings than the average, and in general showed somewhat more concern for his crew's welfare than the rules required. Which is not to say that he was a nice, likable young man. (He was 34 at the time of the mutiny.) He was insensitive to other people's feelings, had a short temper, and was known for his foul mouth - which in the Royal Navy was quite an accomplishment.
Cram 45 young and middle-aged men, and no women, into a 90-foot-long wooden box (or more correctly about a third of it, the rest being stuffed with equipment and provisions)  for eleven months. Men who, for the most part, have grown up with all the privations and hardships of the working classes in eighteenth-century Britain. During those eleven months, sail the wood box halfway around the world (including an unsuccessful attempt to round Cape Horn). Then turn those men loose in Tahiti, where there are plenty of women, limitless free, good-tasting food, constant good, tropical weather, and virtually no rules governing amorous relationships (or anything else).
Leave those men there, with almost nothing to do, for five months, while the breadfruit goes through its dormant period and gets harvested. Then stuff them back into the wood box (with lousy food, no personal privacy, Royal Navy discipline, physically exhausting work, and no female companionship), offering them the prospect of staying cooped up in said box, with an obtuse, insensitive, foul-mouthed boss, for many more months, followed by, at best, a lifetime of misery and privation (in either the Royal Navy or working-class Britain, which was just about as bad).
The British working class endured misery and privation (by 2016 standards) because there was no prospect whatever of living any other way. The crew of the Bounty had learned that life could in fact be a whole lot better and easier. And the only thing stopping them from spending the rest of their lives in paradise was the I'll-mannered, obtuse, self-centered jerk on the quarterdeck.
With 20-20 hindsight, it's remarkable that so many people, from the Admiralty down to Mr. Bligh, thought it was possible that there wouldn't be serious disciplinary trouble during that mission. If Horatio Nelson had been in command of the Bounty, I'm not at all sure he could have stopped the mutiny.
If you're looking for a good summer read, try Dudley Pope's The Black Ship. It's the story of the mutiny on board the frigate HMS Hermione in the West Indies in 1797. The captain, Hugh Pigot, really was a tyrant. One night several sailors broke into his cabin, hacked him to death with their cutlasses, and threw what was left of him out one of the transom windows. Then they slaughtered most of the officers and turned the ship over to the Spanish.
Now that was a mutiny.
    July 2014
Posted by Bakster on Wednesday, July 13, 2016 9:53 AM
That is an excellent synopsis of their hardship, John. But you had me at the "no women" part.
Huh?
Posted by CapnMac82 on Wednesday, July 13, 2016 10:37 PM
jtilley
I have benn given to understand that one of the best things about being "emeritus" is that you can show up whenever you want, pontificate as long as you wants, and never a single paper to grade.
Fourth stripe and immenent beaching in a few scant months may have me a tad scrufft, too.
    May 2003
Posted by jtilley on Wednesday, July 13, 2016 10:58 PM
I haven't been given emeritus rank yet, but I've been given to understand that will happen as soon as fall semester starts.
I could keep my office if I wanted it, but I don't. From my standpoint the two benefits of emeritus status are a free parking permit and library privileges.
So far, retirement is great. I suspect it'll really start to sink in when the new semester starts - without me. As for pontification, that's what this Forum's for - isn't it?
    September 2005
Posted by warshipguy on Thursday, July 14, 2016 7:20 AM
John,
Congratulations on your retirement.  I am currently sitting in my classroom before my summer school classes start today wistfully dreaming of the day I retire.  I will reach my 20 year point of teaching in six years after 24 in the U.S. Navy.
On to Bligh . . . Tahiti was no mystery to the Royal Navy.  Nor was harsh discipline.  I agree that the prospects of the voyage home, coupled with the realities of working class life in England, was unpalatable for some members of the crew, but most of the crew elected to remain with Bligh and did not participate in the mutiny.
What surprises me most about this story is the fact that Fletcher Christian, a Master's Mate and the effective Executive Officer, was the leader of the mutineers.  He led a relatively privileged life on the Bounty.  Yes, he was harassed by Bligh, but that is common among RN life, even today.  To the best of my knowledge, few shipboard mutinies include the officers among the mutineers.  It is also interesting to note that it was the officers and members of the privileged class in New South Wales that later mutinied against Bligh when he was serving as Governor.  And, Bligh had previously served as Captain of two merchant ships during the Peace of Amiens without difficulty. He also served as Captain in ten commissioned warships and as Commodore twice without mutinies. However, he was commonly referred to as, "That Bounty ***" during the fleet mutinies at Spithead and The Nore.
Anyway, I am still trying to wrap my head around the HMAV/HMS issue. To the best of my knowledge, Bounty was not commissioned into the RN.  I'll admit to never really looking into this, and I have always assumed that her status was similar to that of USNS ships today.  Please correct me if I am wrong.
At least I have given you one last minor "paper" to grade!  Confused
Bill
    September 2005
Posted by warshipguy on Thursday, July 14, 2016 8:02 AM
Congratulation on making Captain!
Bill
    May 2003
Posted by jtilley on Thursday, July 14, 2016 8:41 AM
I honestly don't know whether the eighteenth-century British Navy had official "commissioning" ceremonies for ships. The Bounty was owned by the navy, operated under navy orders, was commanded by a commissioned officer, and, so far as I know, flew the Royal Navy ensign. (In those days the red ensign, denoting a "private ship" - one not under the direct command of an admiral.) Her crew were members of the Royal Navy - not temporary employees (like the crews of transports temporarily hired by either the army or the navy). I know of no reason why she wouldn't qualify for the H.M.S. label.
In quite a few years of reading Royal Navy documents, it's often struck me that the abbreviation H.M.S. actually doesn't show up often in pre-twentieth-century sources. My guess is that there was never an official directive that spelled out the use of the abbreviation. Most of the actual manuscripts I've looked at dated from the period 1775-1783. "His Majesty's Ship," and "H.M. Ship" we're common - as were "H.M. Frigate," "H.M.Sloop," etc. (One I remember in particular was a letter from Sir George Rodney to the Admiralty,  describing how two "vessels belonging to his Majesty's Rebellious and Piratical Subjects Armed for War [i.e., either American privateers or warships of the Continental Navy] had, in some harbor in the West Indies, "pointed their guns into his Majesty's sloop the Rover." Rodney responded by sending a couple of "his Majesty's ships" to "chastise them for their Insolence."
(A 1970s grad student copying documents in the National Maritime Museum - in longhand, in pencil, on 5x7 note cards - got accustomed to some odd uses of capital letters.)
Anyway, in my mind both "H.M.S. Bounty" and "H.M.A.V. Bounty" are perfectly ok.
This thread, which started out as a discussion of paint finishes for sailing ship models, has now descended to the trivial - and that's mostly my fault.
    September 2005
Posted by warshipguy on Thursday, July 14, 2016 9:33 AM
John,
Trivial can be fun!
On to the point of this thread . . .  So, what do the rest of you think of using railroad colors for sailing ship finishes?
Bill
