Building from scratch my 1/280 Clipper Great Republic
    March 2005
Posted by philo426 on Saturday, February 11, 2017 7:07 PM
Agreed this is one epic build and the cantilevered display board is pretty unique also.
    December 2012
Posted by rwiederrich on Saturday, February 11, 2017 7:39 PM
Thanks you very much Goldhammer.  I never really thought of myself as an exceptional builder.....more of a throw it together kinda guy.  I have(IMV) limited patience when it comes to repetition.  If I can devise a way to make things move along faster and utalize trickary.....I'm your man.
I am always looking for a unique way to display my models...theme that tells a story...or at least depicts a factual event in the life of the vessel.  In the case of the Great Republic..she burned to the water line before she even set sail on her maiden voyage...so depicting her as a burned out hulk...probably wouldn't be the effect one is looking for.
Here are 3 other examples of unique displays I built for other ships.
The Ferriera(aka Cutty Sark) " target="">
The Cutty Sark rudder repair " target="">
And the clipper Donald McKay " target="">
    March 2005
Posted by philo426 on Sunday, February 12, 2017 12:47 PM
I really like the top picture.How did you construct the water base I want to do the same for my Vernon?
    December 2012
Posted by rwiederrich on Sunday, February 12, 2017 3:13 PM
    September 2005
Posted by warshipguy on Sunday, February 12, 2017 3:45 PM
Exquisite!
Bill
    March 2005
Posted by philo426 on Sunday, February 12, 2017 4:53 PM
Thanks! I was thinking of using rippled plastic shower glass and painting greens and blues underneath it.Much to consider and it really adds visual interest.
    December 2012
Posted by rwiederrich on Sunday, February 12, 2017 7:41 PM
I was looking for a three dimentional look...the depth of the resin over the plexi with color within and underneath really made it pop.
Rob
    December 2012
Posted by rwiederrich on Sunday, February 12, 2017 7:54 PM
It's all ab out depth of field and 3-D effect.
See the anchor..it's above and below the waterline...so is the mooring pontoon/
I even added a supply boat unloading a barrel...the bottom of the boat is visible underneath as well.
 " target="">   " target="">
    July 2013
Posted by steve5 on Sunday, February 12, 2017 8:30 PM
i'm with gold hammer , no way I could come close to that skill level , just love watching you work my friend .
steve
    March 2005
Posted by philo426 on Sunday, February 12, 2017 10:23 PM
Yes awesome work for sure!
    December 2012
Posted by rwiederrich on Monday, February 13, 2017 12:50 PM
Thanks Steve and Philo...I appreciate that very much.
Now back to the Great Republic...I finished up the lower masts and the spanker mast.
I have to now tackle the deadeyes and the futtock shrouds..I also tung oild the spanker and the jib boom.
 " target="">   " target="">    " target="">   " target="">   " target="">
    December 2012
Posted by rwiederrich on Monday, February 13, 2017 6:16 PM
Today I had an hour or so...so I fabricated the futtock shrouds for the masts....There are a plethora of ways one could go about doing this....I kept it simple and will be adding my deadeyes to them later...the same way I did the main deadeyes on the channels.
    December 2012
Posted by rwiederrich on Friday, February 17, 2017 7:40 PM
I've built so many sailing ships over the years and have built them with furled sails with sails and with no sails.  My last big ship (Glory of the Seas) is without sails and my Cutty Sark is without sails.
Well the Great Republic is the biggest and most expansive clipper I have built thus far and I feel sails are appropriate...since she was the largest wooden clipper ever built.
she was enormous...so she needs saild...but not just any sails.....clean, sharp, accurate sails are what's called for.  Well I've opted out of using cloth..since the scale problem will only make the model look clumsy.  I considered silkspan..but this is still too translucent for me.  So I'm going with plain paper(again).
Like anything I do I try a test bed to test techniques..methods...and asthetics.
So the other day I fabricated a master sheet that I duplicated(both sides) that will represent the 2ft panels that will represent the entire sail.
Today, I cut out a test sail and trimmed its outer(Leach lining) and top(Head lining) edges with a 2ft panel and I laid the reef band mid sail. In some cases a foot band will be installed as well.
I did not add the the reef points to the reef band at this time..since the test was about over-all appearance not function.
After the sail was constructed I then gave it an entire dusting of muslin tan paint   to simulate the tan/orange look of faily knew sails(Previously I mentiond about weathering the sails with India ink/alcohol...but upon further reflection and the over all newness of the model itself.....new sails was an accurate choice.
I finished off the course connections at the lower edges of the sail with some stretch and wrinkle folds...simulating the streching of the sail inflated with wind.
I think I hit the kackpot with this technique and it didn't take long..about 30 minutes.  Prior to painting I used one of my wife's fondant(Cake making tool) ball rollers to roll the  stretched roll to the foot of the sail.  With some fine tuning I think this is the clean look I was after.
Rob " target="">   " target="">   " target="">   " target="">   " target="">
    December 2012
Posted by rwiederrich on Friday, February 17, 2017 7:44 PM
I'm looking for a soft full sail..not too stressed or too limp.
Kinda like this(with out the stunsails)
Rob " target="">
Thanks for looking in.
    July 2013
Posted by steve5 on Friday, February 17, 2017 10:18 PM
can't wait to see this through rob , it should look incredible , I put a link for my soleil royal for you under your request . but I'm sure you'll do a far superior job . I went for that old lived in look LOL .
    December 2012
Posted by rwiederrich on Saturday, February 18, 2017 12:16 AM
Nah..nah..Steve..you don't give yourself enough credit...your sails are made very well and are quite convincing and detailed.
I too will really detail the sails out with all the leach, bunt and reef tackle.
I've done sails before..but this time round am going the full Montey.
Scale also has something to do with...so some mods will have to be made.
I have a long way to go before sails..but planning helps a lot.
Rob
    July 2013
Posted by steve5 on Saturday, February 18, 2017 3:24 AM
cheer's mate , that's alway's been my bug bear , too impatient .
steve
    March 2012
Posted by David_K on Sunday, February 19, 2017 11:17 AM
Incredible work, Rob!  The paper sails are sure to look great!  I really ike the creases at the corners, very cool!
And the water diorama you described for that previous build....I remember seeing it in person at your place...it looks like REAL water.  As always, I am impressed.
Dave
        _~
     _~ )_)_~
     )_))_))_)
     _!__!__!_
     (_D_P_K_)
Current Project:  Imai/ERTL Spanish Galleon #2
Recently Finished: Revell 1/96 Cutty Sark
Next Up:  ???
    December 2012
Posted by rwiederrich on Sunday, February 19, 2017 7:21 PM
Thanks Dave.  I feel the sails will be a fantastic addition..since they will be fully detailed to scale.  I think 25+ sails on this build will be spectacular IMV.
Last time I finished a build with a full set of sails was over 25 years ago.
Rob
    December 2012
Posted by rwiederrich on Tuesday, March 21, 2017 8:19 PM
I got to spend a couple of hours working on the GReat Republic today and I finished the masts.  Here are some pics.
Rob " target="">
 " target="">
 " target="">
 " target="">
 " target="">
Rob
    September 2005
Posted by warshipguy on Wednesday, March 22, 2017 5:52 AM
Nice!  It's great to see you back!
Bill
    December 2012
Posted by rwiederrich on Wednesday, March 22, 2017 4:41 PM
Life has changed and I can't work on my ships as often as I did.
Thanks.
Rob
