Lake Ontario 213 year old shipwreck.
    December 2006
Posted by crackers on Thursday, August 18, 2016 12:16 AM
Divers have discovered a unique vessel that sank during a violent storm in November 1803, in Lake Ontario, using high-resolution side-scan sonar. The ship, known as the WASHINGTON, was a single masted sloop, built by Americans on Lake Erie in 1798 to transport goods and passengers between New York, Pennsylvania and Ontario, Canada. Four years later, the sloop was sold to Canadian merchants and portaged to Lake Ontario by a team of oxen. A year later, the ship carrying $20,000 of East India goods from Kingston, Ontario to Niagara, Ontario, was caught in a severe November storm, drowning two merchanta and three crew members. Some wreckage drifted ashore near Oswego, New York. The wreck lies on its keel with its single vertical mast still intact.The WASHINGTON is the second oldest shipwreck found at the botton of Lake Ontario. The oldest known shipwreck is the HMS ONTARIO, a two masted brig that sank in 1780 and found in 2008.
Story and photo by Fox News.  Happy modeling    Crackers
Anthony V. Santos
    July 2004
Posted by stikpusher on Thursday, August 18, 2016 2:36 AM
I saw this earlier today. It is incredible how well preserved that this wooden wreck is over 200 years after she sank!
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    April 2016
Posted by Staale S on Thursday, August 18, 2016 6:12 AM
You see similar wrecks in the Baltic and the Black Sea. Fresh/brackish water in the Baltic, and an oxygen-free environment in the Black Sea past a certain depth, allow wooden wrecks to just sit there for centuries.
    December 2012
Posted by rwiederrich on Thursday, August 18, 2016 8:33 AM
I'm wondering if there would be an interest in raising her?
Rob
    June 2008
Posted by norherman on Thursday, August 18, 2016 8:49 AM
rwiederrich
Rob
 I'm for That.
Dave
    August 2014
Posted by goldhammer on Thursday, August 18, 2016 9:58 AM
The cost to raise her would run to at least a couple of million, and add to that the conservation costs.   Once you pull her out of the water she will start to deteriate and fall apart unless carefully treated and preserved.  While it would be cool to see it done, she is probably better off where she is and the state of preservation she is in.
    May 2003
Posted by jtilley on Thursday, August 18, 2016 1:46 PM
Unfortunately goldhammer's right. The expense of raising the ship would just be the beginning. Conservation would be astronomically expensive - and even after the initial treatment (which would take several years) the ongoing expenses of preserving the ship would be almost as bad.
I'm reminded of the case of the Hunley. The people who started that project estimated that raising her and conserving her would cost something like $3,000,000. It's now up to more like $50,000,000 (if I remember right), and the job isn't close to finished yet. Whether it ever can be finished completely is a question that makes me nervous.
I'm also reminded of a shipwreck excavation project I saw in Holland about thirty years ago. Much of what's now Holland was under water for hundreds of years, and farmers are still plowing up historic ships in fields. So many have been uncovered that the government has several decades' worth of conservation projects waiting in line. The one I saw was still in the farmer's field. The ship dated from the fifteenth century. A team of highly trained conservators was meticulously taking every piece of metal and wood out of it. They had set up a metal platform over the wreck, so they could take pictures from overrhead every day. As each piece came out, they drew pictures of it, measured it, photographed it, wrote a verbal description of it - and burned it. (I took a couple of iron spikes, which have since rusted almost beyond recognition.) The Dutch were smart enough to realize that the money and manpower necessary for a thorough conservation job on every Dutch shipwreck simply wasn't going to be available before the ships rotted beyond saving.
I agree with goldhammer: this one's better off under fresh water.
    June 2014
Posted by Tanker - Builder on Friday, August 19, 2016 6:21 AM
Hi Proff !
 Knowing that like many , you understand what would happen if she was brought up , I would steadfastly agree with the idea of leaving her alone .They can and should do as much photo documentation as possible without even touching her though .    T.B.
    June 2014
Posted by Tanker - Builder on Sunday, August 21, 2016 8:20 AM
Here's an Idea ;
   Take a large lexan case .Tint the inside ever so slightly with a mist coat of " Tamiya Sea Blue " Candy overcoat .
   Then cover the base with Model Rail-Road " Fine " ground cover sand. ( H.O.Scale ).
 Now create the debris field . Then insert ship . Cover and seal .You will now have a nice display of a Great Lakes sunken ship with an accurate appearing subject . Add a name - Plate and you are done .     T.B.
