Ship Railings: Vertical Bars
    June 2003
Posted by allan on Wednesday, August 24, 2016 11:48 PM
Anyone know if there is available in 1/700 PE ship railings with vertical bars?
I had primed myself to start building a civilian ship when I got stopped cold on my tracks.  I discovered that the ferry I was going build had vertical bar railings.
No bucks, no Buck Rogers
Posted by Big Jake on Thursday, August 25, 2016 7:58 AM
There is a lot of railing for 1/700. in that scale its almost impossible to see, I did a quick google search, here is the link
https://www.google.com/search?q=1/700+bar+railing&biw=1920&bih=994&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwjdi4POztzOAhUI62MKHfulDs8QsAQIPg
Posted by Don Stauffer on Thursday, August 25, 2016 8:56 AM
Not exactly sure what you mean by vertical bars.  Do you mean with the stanchions vertical and horizontal rails?  This is the most common.  There are also pe railings for stairways that are inclined at an angle.
    August 2005
Posted by EdGrune on Thursday, August 25, 2016 9:49 AM
I think he means like a picket fence, upright bars attached to top and bottom runner rails.
Not aware of any in 1 700 scale.    You might find PE fencing in the popular railroad scales
    September 2012
Posted by GMorrison on Thursday, August 25, 2016 9:55 AM
There are square open grid PE sheets around. They are some amount of work, a lot of attachment points to cut and nubs to file. High rate of loss too.
    June 2003
Posted by allan on Thursday, August 25, 2016 10:07 PM
    September 2012
Posted by GMorrison on Thursday, August 25, 2016 11:22 PM
Seriously Allan. That's a tall order At any scale, let alone 1/700
    April 2016
Posted by Staale S on Friday, August 26, 2016 3:59 AM
Ouch. If you can'not find something expressly made for the purpose (which I doubt exists) perhaps something like PE fences or ladders can be adapted? It doesn't have to be made for ships, really. As long as it is vertical-bar and the right height (or width, depending!) it should be effective.
Posted by Don Stauffer on Friday, August 26, 2016 9:21 AM
I just checked Tom's Model Works.  They have generic railings in 1:700, both three bar (rail) and two bar.
    June 2003
Posted by allan on Friday, August 26, 2016 10:06 PM
I figure Ill try ordering some 1//350 PE hanging ladders in the hopes some of them will be wide/tall enough to stand as 1/700 railings.
Posted by CapnMac82 on Saturday, August 27, 2016 5:35 PM
Might be a good time to look into the DIY photoetch. you'd need to be bale to represent the rails with precise linework, but, the rest is fairly simple.
    June 2014
Posted by Tanker - Builder on Saturday, August 27, 2016 6:05 PM
Hi ;
 How about this ? Try to find Wrought iron fencing in the size you need  .I think " N " Scale might work , if not " Z " scale by KIBRI .
    May 2008
Posted by ejhammer on Saturday, August 27, 2016 7:55 PM
Captnmac has a good idea. I needed to have 18 sets of rotors for helicopters and only 4 to a set. It would have cost nearly $200.00 for enough PE sets to do it. The PE making stuff cost me about $150.00 including extra film and sheets. A bit of a learning curve doing the artwork and PRESTO - I had 20 sets of rotors. AND, the ability to make them in any scale I wanted by simply resizing the artwork. I've used it for other items and occasionally made specialty stuff for others. EJ
Completed - 1/525 Round Two Lindberg repop of T2A tanker done as USS MATTAPONI, USS ESSEX 1/700 Hasegawa Dec 1942, USS Yorktown 1/700 Trumpeter 1943. In The Yards - USS ESSEX 1/700 Hasegawa 1945, USS ESSEX 1/700 Dragon 1944, USS ESSEX 1/700 Trumpeter 1945, USS ESSEX 1/540 Revell (vintage) 1962, USS ESSEX 1/350 Trumpeter 1942, USS ESSEX LHD-2 as commissioned, converted from USS Wasp kit Gallery Models. Plus 35 other plastic and wood ship kits.
    June 2003
Posted by allan on Tuesday, August 30, 2016 3:07 AM
Im probably not ready to dabble with making my own PE yet. I basically at zero when it comes to that. I have ordered 1/350 hanging ladders to see if that would work.  Ill also start looking around for them fences as Tanker pointed out.  If all fails, Ill start studying photo etching.  :)
    June 2014
Posted by Tanker - Builder on Tuesday, August 30, 2016 11:36 AM
You should;
 Maybe look in a KIBRI brand catalogue - H.O. and N. scale model railroad wrought iron fencing . I am sure they Will have something that will work .  T.B.
