Panel on Frame
    June 2014
Panel on Frame
Posted by Tanker - Builder on Saturday, October 8, 2016 1:57 PM
Hmmm;
    I got to thinking .( I know , dangerous thing for me ).   How about this . Say you want to build a ship out of plastic . You know what you want . There's just no plastic model of it . Shoot , you can do wood ( it's been done for hundreds of years after all ).
    Nah ; Don't want to have sawdust all over the small apartment . So use plastic .You can do this one of two ways . Solid frames or laminated frames . In the case of laminated frames , I have found that you actually do get more strength with laminating !
 Microscopically , plastic sheet does have grain . Now , clear lexan , if cast , doesn't . This is important to know . If you choose to laminate then you must do this . One full piece on one side the same , split in two , for the middle pieces and another whole piece for the other side .
   Of course this is for larger scales . Smaller scales can be handled by cutting the frame shape out of sheet . .060 is the preferred thickness . You could use Evergreen strip and heat shape it , But , remember , plastic still has memory and like metal , wants to return to it's original shape .
   With sheet you defeat this memory . Using your plans and  being careful you should be able to create the ship hull . It takes a lot of patience but it works .
   Want to shortcut ? How about waterlining ? This is where you build an eggcrate type structure and while building generate the shape you need . You must have a waterline and deck plate .Keel plate ( in the center .) sets the shape of sheer and deckhouse . Yes folks , just like papermodels .
    Then you do something different from papermodels .You make doublers on the edges of the frames .Then you glue shaped panels in place in each location . You can allow for bulwarks in scale by doubling the edges of the deck here and then putting scale thickness bulwarks on the upper edge .
    Now , I've run out of words . Think about it and try it .  T.B.
Posted by CapnMac82 on Saturday, October 8, 2016 4:22 PM
Part of my bread and butter toolbox.
Had planned on building USS Sand Diego, as CL (AA) in 1/16"=1'-0".  But, the supplier for the hull backed out on stacking that one in that scale.  Since I already had 8 5"/38 turrets, a pair of torpedo tubes, all the goodies and extras in 1/16", I was not going to just change to 1/8" scal (not that I had 7' of bench space either).
So, Used a mix of 0.040 and 0.060 and a seto fr Floating Drydock plans for the body sections.  Did not use a keel-aigned plate, instead used pacers cut to the station span dimension on either side of the centerline.  I used triangular gussets cut with a chopper so that they were 90º exactly.
Was up to the 0200 level when all that work vanished in a move (left behind, crushed, just lost will remain a mystery along with all those single socks).
