Monitor HMS Roberts
Monitor HMS Roberts
Posted by Don Stauffer on Monday, March 6, 2017 9:18 AM
I have put aside my WW1 torpedo boat for awhile to do a kit.  The last monitor, the HMS Roberts, is a great Trumpeter kit (1:350).  This relatively inexpensive kit is loaded with PE and lots of parts!  However, it is a bit of a challenge.  Some of the parts, while exquisitely molded, are super tiny, and the PE frets are only 3 mil thick, with super narrow features. If you look at them cross-eyed the parts bend and distort!  Still, it looks like it will be a great model when done.  Sort of a bulldog look, lots of power in a small package.
Have the hull complete and painted, with the deck in place.  Working on superstructure and little detail subassemblies now.
Lots and lots of AA guns bristling all over this thing, each gun emplacement several styrene parts and multiple pieces of PE!
    January 2015
Posted by PFJN on Monday, March 6, 2017 10:29 AM
Hi,
Looks nice, thanks for sharing.  I'm anxious to see how this build turns out.
Pat
1st Group BuildSP
    April 2011
Posted by John T on Monday, March 6, 2017 11:06 AM
Very nice! Please keeps the updates coming.
    June 2014
Posted by Tanker - Builder on Monday, March 6, 2017 4:19 PM
Don;
 Hey , Can I say weird but good ? Strange hull . But this is the first time I've seen this kind of monitor hull . Nice painting so far !  T.B.
    May 2009
Posted by Pawel on Monday, March 6, 2017 4:26 PM
Hello Don!
It's like a battleship that has been sick when it was young and it didn't grow, right? :D
I like the look s of that warship - good luck with your build and have a nice day
Paweł
www.vietnam.net.pl
    December 2015
Posted by templar1099 on Monday, March 6, 2017 4:50 PM
Eclectic choices Don,I'll keep checking on it.
"le plaisir delicieux et toujours nouveau d'une occupation inutile"
    July 2010
Posted by docidle on Monday, March 6, 2017 9:27 PM
Looks great so far Don! May I ask what PE set you are using and what paints and colors?
Thanks,
Steve
Posted by Don Stauffer on Tuesday, March 7, 2017 8:44 AM
Pawel
Hello Don!
Paweł
I envision it as a battleship that was running full speed astern, and ran into a cliff :-)
Posted by Don Stauffer on Tuesday, March 7, 2017 8:47 AM
docidle
Thanks,
Steve
It comes with extensive PE.  I think it was a terrific deal- I got mine for something like 48 bucks.  I think it lists at 80.  Considering the price of newer kits these days, that is pretty good. It is supposed to have over 500 parts, but not all the parts are used, so I don't know if the 500 refers to parts provided or parts used.
Paints are all MM enamel.  Blue is mixed a bit to reduce saturation- couldn't find an exact match to colors specified for the blue.
    December 2003
Posted by scottrc on Tuesday, March 7, 2017 10:12 AM
Don Stauffer
Pawel
Hello Don!
Paweł
When I first saw it, I thought is was what turned out to be the third Rodney class battleship, but after MOD cuts went into effect.
I am looking forward to seeing much more of this interesting model.
Scott
Posted by Don Stauffer on Friday, March 17, 2017 12:05 PM
Completed the superstructure assemblies, ready to glue these to the main deck.
    July 2003
Posted by ridleusmc on Friday, March 17, 2017 10:14 PM
The Abercrombe and Roberts are very interesting ships.  I like the one huge turret on a relatively small vessel.  I also like the wide, sloped-out hull.  The Brits come up with some clever and interesting solutions.  I can't wait to see yours built.
-Chris
Posted by Don Stauffer on Wednesday, March 22, 2017 8:52 AM
Boy, am I having a fit with the PE on this kit!  My first problem was that I kept breaking parts along bend lines.  A friend suggested maybe the brass was hardened, and I should anneal it- problem was I had already painted a lot of it.  Turns out, the problem was that several of my bending tools had too sharp an edge.  On 3 mil brass it does not take a very deep scratch to scratch through a high percentage of the thickness!  I have gone to wood for the tool that sits on inside of bend- havent broke one since.
Next problem- the brass is actually too soft!  Much of the mast detail are big arrays of radar antennas- dipole array.  Because of the size of the pieces compared to thickness, they bend from inertia if I move the piece at anything other than a slow crawl!  The arrays look like they are made of spagetti!  I am remaking one of the arrays from soldered brass rod.
    September 2013
Posted by Marcus McBean on Wednesday, March 22, 2017 11:55 AM
Don, I hear your pain.  The PE that came with the Dragon Scharnhorst was the some of the worst I had to work with.  Never thought that the tools were to sharp on the edge.  Will have to give the wood method a try next time.
Posted by Don Stauffer on Wednesday, March 22, 2017 2:46 PM
Got the superstructure assemblies glued to hull.  Now for the masts,  which are mostly pe!
BTW, here is the PE antenna, all bent up and askew!
    September 2013
Posted by Marcus McBean on Wednesday, March 22, 2017 7:44 PM
Brass rod is the way to go on that antenna.
    July 2010
Posted by docidle on Wednesday, March 22, 2017 11:54 PM
I know about the "quality" of Trumpeter brass Don and I agree with Marcus, it is some of the worst out there. If you look at it sideways it breaks!
That was the reason I asked earlier what PE you were using. I am looking at either the White Ensign or Flyhawk sets for mine. Just have not decided which one yet and I have a mess of projects I need to try and finish before i start on another one. And it just means more money into it.
Thank you for the heads up on the paint you are using also. I picked up the ColourCoats paints for it.
i love what you have done so far, this is a really cool looking ship.
Steve
Posted by Don Stauffer on Friday, March 24, 2017 2:15 PM
Here is my first attempt at doing the antenna array from small brass rod.  I think it will be a keeper.  One more to do.
The antenna arrays aside, I am getting the hang of working on the incredibly thin and light PE pieces.  The bridge (I guess it is the bridge) up on the forward tripot mast is a real work of art, three styrene pieces and ten PE pieces.  I will let the PE antenna for this mast go till the last minute and see if I can use it- if not back to the soldering iron!
    June 2014
Posted by Tanker - Builder on Friday, March 24, 2017 5:11 PM
Hey Don !
 That's a nice rendition of that flimsy antenna . Now the next picture .That might be the bridge of a Steampunk airship or a British Monitor . Looks good ! T.B.
    September 2013
Posted by Marcus McBean on Friday, March 24, 2017 6:44 PM
Nice work making that antenna.  I found using epoxy works better than CA attaching the bass rod to the ship.
    April 2016
Posted by Staale S on Friday, March 24, 2017 7:34 PM
Don Stauffer
Not the bridge, I think. More like fire-control or spotting.
Posted by Don Stauffer on Tuesday, April 4, 2017 1:09 PM
Disaster!  Or near disaster, anyway.  I had mounted the upper part of the forward mast, containing the fire control (?) cab and some antennas.  Then the next day, looking at it, I found I had glued it in backwards!  Thank god for CA debonder!  Yesterday I applied debonder to the joint (floor of the cab and the junction of the three tripod legs).  I gently applied upward pressure (downward, actually, as I turned the hull over to see the bottom of the cab better).  It eventually released.  That cab is made up of 3 styrene parts and zillions of photo etch pieces.  There were 12 gussets glued to the floor, and these came loose but these should not be a big problem.  Nothing else on the upper portion of the mast came loose. I am now gluing back on the gussets, piece by piece.  I will have to repaint that cab.  The debonder did an excellent job of stripping the paint off the floor of the cab and all the gussets.
    May 2009
Posted by Pawel on Tuesday, April 4, 2017 3:06 PM
Well, I'm glad you were able to save it, Don! Good luck putting it all back together and have a nice day
Paweł
www.vietnam.net.pl
    April 2016
Posted by Staale S on Wednesday, April 5, 2017 3:28 AM
Don Stauffer
Ouch... I hate it when that happens :)
    August 2007
Posted by DUSTER on Wednesday, April 5, 2017 3:43 AM
Good Save Don.  Glad you can reapply the parts and paint so "easily" .
Steve
    October 2003
Posted by sharkbait on Wednesday, April 5, 2017 1:31 PM
Thread drift Google does sometimes lead one astray leading to stranding on the reefs of knowledge. Found this WW1 battle where the RN used monitors. https://en.m.wikipedia.org/wiki/Battle_of_Rufiji_Delta Thought some may find it of interest. Back to the Thread
You have never been lost until you've been lost at Mach 3!
    March 2010
Posted by Bocks Suv on Wednesday, April 5, 2017 3:40 PM
Ii did somehting simliar on a rushed Concorde build a few months ago.  Even as a commission build I had a feeling no one would notice ( L engine exhaust cover put the right sire and vice versa), but I would know. I actually pried them up with minimal damage and did the swap. It pays to always dry fit and complete a section.
I built a 1/350 Trumpeter HMS Montrose last summer. My eyes are still crossed from the micro pieces and PE. That said, would moving up to 1/200 scale ships make life better or worse?   Logic dictates that all the tiny pieces would be 75% larger, BUT would Trumpeter be so cruel as to then split those same pieces into 2 or 3? Sure more detail and parts to brag about but just as tedious as the 1/350 ...or worse! Perhaps there's another brand that's easier to work with but just as detailed.
Good luck with the Roberts. Hope you have the PE deck rails. They'll bring the whole thing together.
    January 2015
Posted by PFJN on Wednesday, April 5, 2017 8:21 PM
Hi,
This looks like a very interesting ship, and you build looks great so far.  I can't wait to see the finished model.
Pat
1st Group BuildSP
Posted by Don Stauffer on Thursday, April 6, 2017 8:47 AM
Got the cab rebuilt and painted yesterday.  Hope to get it mounted on tripod legs today.
Posted by Don Stauffer on Thursday, April 20, 2017 9:22 AM
Finally got  the upper mast with its cab/top reinstalled correctly.  Trouble was, I made a mistake in building the cab/top assembly, which caused it to only fit backwards!  Faces right way now!
