what knife or blade number for molded on railings? 1/426 scale
    September 2009
Posted by Felix C. on Saturday, December 9, 2017 3:03 PM
Cutting the railings off a 1/426 kit and my knife is not making any headway.
I am using an el cheapo three knife set which did ok for 1/72 work. Minimal cutting there, only off the sprue.
So I went to Michaels and see some X-acto and other brand blades with blade #s
Which one should I use?
    August 2005
Posted by EdGrune on Saturday, December 9, 2017 3:32 PM
Xacto #17 Lightweight Chisel or eqivalent.
    September 2012
Posted by GMorrison on Saturday, December 9, 2017 4:57 PM
I also like to use single edge razor blades.
    April 2005
Posted by ddp59 on Saturday, December 9, 2017 6:17 PM
if the deck is off the Arizona i use small wire cutters to take most of the railing off then cleanup using #11 blade.
    September 2009
Posted by Felix C. on Sunday, December 10, 2017 6:31 AM
Wire cutters for initial cutting of lengths and straight razor for cleanup  did the trick. It was less money at the hardware store than an X-acto chisel!!!
I guess hobby tools have a Corvette Tax!
    April 2005
Posted by ddp59 on Sunday, December 10, 2017 9:09 AM
are you working on the Arizona or the Currituck class seaplane tender?
    September 2009
Posted by Felix C. on Sunday, December 10, 2017 3:39 PM
Arizona
    September 2012
Posted by GMorrison on Sunday, December 10, 2017 4:12 PM
Ain't that a pain.
    April 2005
Posted by ddp59 on Sunday, December 10, 2017 6:22 PM
GMorrison, on the Arizona or taking the railing off as i've done that to 10 of them so far when converting them to the OBB's from the Wyoming to the Colorado classes?
    June 2014
Posted by Tanker - Builder on Monday, December 11, 2017 8:47 AM
Hi ;
 I specifically use the good old number 11 slid backwards gently to remove the old REVELL  "Rail Walls !" It has always worked best for me .
