Muffler color on PT Boats
    April 2010
Posted by Bob H on Wednesday, December 13, 2017 3:30 PM
I am building Revlls PT-109 with a lot of photoetch and scratch building. I would like it accurate as I am able, so should the mufflers be the same color as the boat. Should there be any rust on them.
    November 2008
Posted by plasticjunkie on Wednesday, December 13, 2017 6:31 PM
They were the hull color. Eventually some rust would form.
Google "PT Boat muffler details" for some pictures.
Edit:
I see that you found the PT Boat Forum and got a direct answer. I stand corrected on the rust since the mufflers were made out of copper. That is a great site by the way.
 GIFMaker.org_jy_Ayj_O
    April 2005
Posted by ddp59 on Wednesday, December 13, 2017 7:38 PM
was the boat in service or just about to go into service? if in service then the paint would have been burnt off the mufflers due to engine heat. if going into service the paint would probably be same color as hull.
    October 2003
Posted by sharkbait on Thursday, December 14, 2017 12:43 PM
Some good referances here ...part 1 of 3
https://youtu.be/Z8tQP3s9DIQ
2 of 3
https://youtu.be/8e6Ei5UvLqI
3 of 3
https://youtu.be/MN47z3n52-c
You have never been lost until you've been lost at Mach 3!
Posted by CapnMac82 on Sunday, December 17, 2017 3:35 AM
It's also important to remember the PTs had dual exhausts--in low and cruise speed the exhasurt was trunked into the water.  That water immersion helped keep the pipes cool. preventing heat corrosion.
At high speeds, the mufflers were bypasses to direct venting.
So, they did not have much reason to rust, or, for that matter, weather, beyond being salt spray.
