Newby Sub questions
    April 2010
Newby Sub questions
Posted by Theuns on Wednesday, March 28, 2018 9:32 AM
I want to try my hand at a Sub or U-boat soon but know very little about the subject.
The question I have , regarding WW2 subs is that they seem to be rather rusty from long deployments, how do you guys "rust" the hulls? I see there is also allot of streaking from what I can assume is faided paint and other "stuff" running down the hull.
Would the wooden decks of German U-boats be natural in colour or were they also the same grey as the hull?
Since my budget is very tight I am looking at the Revell 1/350 VIIc kit, although it is rather small, I think it would be a good base to try new tecniques on?
I rather like the shape of the new generation of neuclear boats like the Sea wolf and Los Angeles class but I think to "weather" them would be very difficult as they dont rust and look very clean and clinical.
Theuns
Posted by Bish on Wednesday, March 28, 2018 10:23 AM
I am pretty new to Subs as well, working myself up to a 72nd U-Boat. But i do know that U-Boat decks were painted black though of course this would fade and wear over time. From what i can tell, WW2 boats did not rust much either, and i can't see there being a lot of chipping.
    February 2011
Posted by Hokey on Wednesday, March 28, 2018 10:56 AM
Nice!  I’m a sub guy. Built a few. After base coats painted but before any of the final weathering techniques, I applied black oily wash to all raised and recessed surfaces of boat, waited a few hours to semi-dry then removed excess from all. This creates depth and shadows.
For weathering then, I used a combination of white/light grey and rust color oil paints thinned to dot areas of salt water drainage and rust. Let sit for a few hours or longer then with thinner and thin brush I pulled down the dots on water drainage and rust dots and then softened and blended with q-tip.
The decks are dark stained wood but over that base color i used a washed out tan oil cover to try to highlight worn areas.
 I have several 1/350 I’m not going to build and would sell.
    April 2010
Posted by Theuns on Wednesday, March 28, 2018 11:45 AM
Ha Yes, that is what I mean. So rust streaks are fairly limited to places where drain holes might be and the light grey is sea water stains?
Theuns
    February 2011
Posted by Hokey on Wednesday, March 28, 2018 11:55 AM
Yes sir.
