Hull paint
    May 2017
Hull paint
Posted by armor 2.0 on Wednesday, April 25, 2018 3:46 PM
Whats a good color or mixture for hull antifouling red. Perferable tamiya acrylic.
    August 2005
Posted by EdGrune on Wednesday, April 25, 2018 3:51 PM
It varies.  Whose navy?
Tamiya makes a hull brown which is appropriate for the IJN
    May 2017
Posted by armor 2.0 on Wednesday, April 25, 2018 4:14 PM
Titalic ship model
    August 2005
Posted by EdGrune on Thursday, April 26, 2018 2:02 PM
armor 2.0
Titalic ship model
Unfortunately the Titanic Research and Modeling Association (TRMA) website is no longer active.  A number or years ago I recommended them in response to the  same question posted here on FSM
At the time it was Rustoleum Red Primer in the jumbo economy-sized rattle can.
Art Braunschweiger's Titanic Paint reference, documenting his museum-built of a Titanic model recommends Floquil Boxcar Red.  Unfortunately Floquil is now OOP.
Check the model railroad shops to see what they have available for Boxcar Red.
    July 2008
Posted by jeffpez on Thursday, April 26, 2018 2:27 PM
Floquil is sadly gone but Testors, who owned them, has brought out many of the more popular colors in their Model Master acrylic line. They have bocxcar red flat #4881 and it's the same color as the old Floquil enamel.
Posted by CapnMac82 on Thursday, April 26, 2018 6:47 PM
Titanic had, IIRC, more of a red lead paint scheme.  Which would probably want mixing Flat Red with Medium Gray--how much will be by eye.
Your references will be a better guide than some absolute formula.
And, there's "scale effect" to consider, as well.  So, your color needs to be a bit paler at 1/350 than at 1/144 or larger.
A person can be easily forgiven for just shooting a coat of Hull Red on--after all, no one is likely to pop up with digital photos of the launching to prove you wrong.
It's rather a bit like arguing over which black to paint the hull (me, I'd use NATO Black for scale effect, and to pe able to pick out details using "straight" black).
My 2¢; you local currency may differ.
    May 2017
Posted by armor 2.0 on Friday, April 27, 2018 6:32 AM
CapnMac82
Thanks you for the reply good information I get so wrap up in the accuracy deal that I take all the fun out I'm thinking tamiya hull red with a little flat white added. I like your suggestion  flat red and medium gray.
Posted by Don Stauffer on Friday, April 27, 2018 9:02 AM
I use Model Master British Crimson for most salties, red oxide (like Rustoleum red primer) for fresh water ships.
Since seeing the portion below waterline is not a realistic viewing situation, I don't worry about scale effect for full hull ships mounted above a base.
