Resumption of Model Shipways Harriet Lane..
    March, 2005
Posted by philo426 on Thursday, September 06, 2018 4:20 PM
Re started the Harriet Lane.I starred the deck houses and will run the wires through the hull and display base with a plug in 4 AA battery power source whuch has a built in on/off switch
    May, 2008
Posted by ejhammer on Thursday, September 06, 2018 8:19 PM
Great idea. Can you explain more about how you wired it and the parts you used? When I did my 1/700 ESSEX I lighted it, but had a 4 AA battery box in the bottom of the base. What a pain to change the batteries. EJ
Completed - 1/525 Round Two Lindberg repop of T2A tanker done as USS MATTAPONI, USS ESSEX 1/700 Hasegawa Dec 1942, USS Yorktown 1/700 Trumpeter 1943. In The Yards - USS ESSEX 1/700 Hasegawa 1945, USS ESSEX 1/700 Dragon 1944, USS ESSEX 1/700 Trumpeter 1945, USS ESSEX 1/540 Revell (vintage) 1962, USS ESSEX 1/350 Trumpeter 1942, USS ESSEX LHD-2 as commissioned, converted from USS Wasp kit Gallery Models. Plus 35 other plastic and wood ship kits.
    March, 2005
Posted by philo426 on Friday, September 07, 2018 9:41 AM
Well I wanted the paddle wheels to turn although I will never put it into the water.I used an AMT Slot Stars mechanism and made the wheels from turned.80 styrene with mahogany planks as paddles.When I make the display base ,I Will cut a rout for the wires and connectors.
    May, 2008
Posted by ejhammer on Friday, September 07, 2018 9:47 AM
Thank you. I need to find a source for the male and female plug for the base and the battery box with a switch. Thanks for your info. EJ
    March, 2005
Posted by philo426 on Friday, September 07, 2018 12:56 PM
I found these connectors at Harbor freight and the battery box at work.
    July, 2014
Posted by Nino on Sunday, September 09, 2018 5:48 PM
     Beautiful  job on the Ship and the gearing.  No cheap nylon teeth here.Those Paddlewheels are going to "sing".
How was the MSW Harriet Lane to put together?  Much sanding?
     And I am curious, is the kit about the same size as the 1/144ish Pyro/Lindberg   Harriet Lane-Civil War Blockade Runner?  The old Pyro kit's hull is 15.5" and it is about  18" long including bowsprit.  The story is that Pyro copied the Model Shipways kit.
 Thanks for starting this thread.
       Nino.
    March, 2005
Posted by philo426 on Tuesday, September 11, 2018 1:26 PM
Thanks for the kind words!She is about 19 inches long.I have heard that Pyro did pirrate this kit but I peronally do not know it for a fact .
    March, 2005
Posted by philo426 on Tuesday, September 11, 2018 1:28 PM
I got the deckhouse painted and installed.
    March, 2005
Posted by philo426 on Tuesday, September 11, 2018 1:30 PM
I got the whistle together.
    March, 2005
Posted by philo426 on Friday, September 14, 2018 9:43 AM
Okay!I used wire for the handrails atop the wheel boxes and the kit supplied stanchions!Next up ,I have to construct the skylights.
    July, 2013
Posted by steve5 on Friday, September 14, 2018 4:21 PM
just caught up with this thread  . looking very cool .
    March, 2005
Posted by philo426 on Saturday, September 15, 2018 3:11 PM
Thanks!
    December, 2010
Posted by 1943Mike on Saturday, September 15, 2018 9:30 PM
Looks very good so far.
Question: how fast (rpm's) will the paddle wheels turn when you throw the switch? Since you have no desire to ballast and launch your ship I'm assuming you've got the mechanism geared down enough so it'll look realistic?
"Le temps est un grand maître, mais malheureusement, il tue tous ses élèves."
Hector Berlioz
    March, 2005
Posted by philo426 on Tuesday, September 18, 2018 3:01 PM
Yes i think 3 volts might be better.I used some parts from a Minicraft titanic to add skylights and ventilators. i turned a plastic ring with mt dremel and added eyelets to chain  down the stack.
    March, 2005
Posted by philo426 on Saturday, September 22, 2018 10:48 AM
Added hatches and a skylight aft and added the Dalghren guns.
    March, 2005
Posted by philo426 on Sunday, September 23, 2018 8:20 AM
Cut out the rudder and added gudgeons and pintels.
    March, 2005
Posted by philo426 on Wednesday, September 26, 2018 6:55 AM
Got I mounted upl
    March, 2005
Posted by philo426 on Thursday, September 27, 2018 10:07 AM
Made the wheel house mounted the wheel and put on the pedestal for the binnacle.  construction the masts will commence soon.
    March, 2005
Posted by philo426 on Friday, September 28, 2018 8:10 AM
Got the ships boats ready and painted.
    March, 2005
Posted by philo426 on Friday, September 28, 2018 4:35 PM
Mounted up the davitts and boats.
    March, 2005
Posted by philo426 on Saturday, September 29, 2018 1:36 PM
Started building the masts and installed the eylets.
    March, 2005
Posted by philo426 on Tuesday, October 02, 2018 9:44 AM
Getting the deadlines ready for the ratlines,
    March, 2005
Posted by philo426 on Tuesday, October 02, 2018 9:45 AM
    March, 2005
Posted by philo426 on Wednesday, October 03, 2018 7:50 AM
    December, 2003
Posted by scottrc on Wednesday, October 03, 2018 10:41 AM
Cool work on functioning side wheels on your Harriet Lane.
    March, 2005
Posted by philo426 on Wednesday, October 03, 2018 3:37 PM
Thanks!
    March, 2005
Posted by philo426 on Friday, October 05, 2018 3:15 PM
Further foremast work and ratlines.
    July, 2014
Posted by Nino on Friday, October 05, 2018 4:58 PM
philo426
... turned a plastic ring with mt dremel and added eyelets to chain  down the stack.
  The Chain to support the stack looks a bit large. Is that what came with the kit?
The ship is looking better and better. The deck "furniture" is looking real good!  Great work.
      Nino.
    March, 2005
Posted by philo426 on Saturday, October 06, 2018 8:52 AM
Yes the chains are a but large but do impart a steampunk vibe I liked.Rigged up the spars.
    March, 2005
Posted by philo426 on Saturday, October 06, 2018 8:53 AM
