Jenny Shrimp Boat build
    January 2012
Posted by fright on Monday, March 18, 2019 11:01 AM
The minute I came across this 1:60 scale kit while looking at other Lindberg model ships and boats online, I immediately flashed upon Forest Gump's shrimp boat, named after the love of his life (next to momma). I purchased this on Ebay a few months ago and it's been sitting on my shelf while I was finishing up on another kit.
I'm looking forward to having a fun time with this project. There are not a lot of parts with this kit but I do like what I see. I did a preliminary fitting with the hull and deck and they go together far better than they did with my Nantucket. It comes with some figures but I will only be using two. One for Forest and the other for Capt. Dan.
I cleaned the parts by letting them sit in some soapy water and then rinsed and let them thoroughly dry before I spray painted all of the parts with gray primer. In the movie, Jenny looked pretty weathered when Forest started his enterprise in shrimping. I watched some videos on using hairspray and salt techniques for creating weathered paint effects, so I gave it a try.
I sprayed a light coat of flat white on the hull and let dry. I then dabbed on some blotches over the hull made up of red, yellow and greenish-blue acrylic paint. Again sprayed a thin coat of white and when dry, I used a toothbrush and scrubed certain areas to show the underneath colors.Not satisfied, I tried the course salt method of wetting surface, sprinkling salt and letting it dry. Then sprayed another layer of white and brushed off the salt crystals. I really liked the way it turned out.
I repeated the same process for the decks, but I did spray a layer of brown over the gray primer before I started the hairspray/salt routine and white paint. After the salt step, I brushed a grayish acrylic wash over the decks. Still more paint needed but here are my results so far. 1st picture is from the movie. (Note: my decks and cabin are not glued at this time)
Robert O
    May 2013
Posted by hogfanfs on Monday, March 18, 2019 11:06 AM
Wow! She's looking really good! I love the weathering!
 Bruce
 On the bench:  1/48 Eduard MiG-21MF
                        1/35 Takom Merkava Mk.I
    January 2012
Posted by fright on Monday, March 18, 2019 9:25 PM
Bruce - I thank you for the compliment. I owe a lot of it to watching videos on youtube and searching thru articles and posts on this subject.
Robert O
    October 2016
Posted by DasBeav on Monday, March 18, 2019 11:40 PM
Looking good, so far. I picked up the same kit at Ollies. I usually build WW2 planes and tanks, but looking to do a boat to break up the monotony. I have seen this model built up really nice. I will be following. Have fun!
 Sooner Born...Buckeye Bred.
    January 2012
Posted by fright on Tuesday, March 19, 2019 9:26 AM
Cheers Das ! Pretty much the same here. I'm hoping I can do a relatively quick build with this kit before I tackle my next 'idea'. I picked up Lindberg's Robert E. Lee side-wheel steamboat and I'd like to try to get it to represent the Sultana steamboat from the Civil War disaster. There's always hope !!!! Enjoy your week.
Robert O
    June 2014
Posted by Tanker - Builder on Tuesday, March 19, 2019 10:01 AM
Well !
 I must say old chap ! You certainly have the nature of the beast . Well done on the weathering . I have always liked this old Lindberg boat kit because of all the conversions you could do to her .This one doesn't need it . T.B.
    January 2012
Posted by fright on Tuesday, March 19, 2019 11:22 AM
T.B. - Thank you for that comment on this kit by Lindberg and, yes, this little boat is a fun little project. I certainly have improved my skills with each new kit and there's so much to learn. I also enjoy the history that each model represents. With that, have yourself a good week Wink
If you haven't already, check out Don Stauffer's build that he's got going on this Lindberg kit. It looks great!
Robert O
    September 2012
Posted by GMorrison on Tuesday, March 19, 2019 11:29 AM
The boat in the movie is wood. The set folks added a LOT of rust streaks, I suppose from the deck equipment. I've seen a lot of fishing boats, they usually are kept up a little better.
The pilot house windows were pretty much blacked out, as the owner was inside driving.
    January 2012
Posted by fright on Tuesday, March 19, 2019 11:36 AM
GM - I'm going to try to give it the scene where Forest is at the the wheel near the stern and Capt. Dan is up in the rigging with the American flag. There is Dan's wheelchair sitting at the starboard rear corner. As for the boat, I'm trying my best to copy the paint and weathering look from the movie. I'm hoping I can duplicate most of this ;)
Robert O
    September 2012
Posted by GMorrison on Tuesday, March 19, 2019 11:37 AM
Yep, that stern wheel is a fiction. But that's the beauty of it.
    January 2012
Posted by fright on Tuesday, March 19, 2019 12:52 PM
Thanks for pointing out about the fictional wheel that was seen at the stern! I'm also toying with possibly using a model pier to duplicate the scene of Forest's boat slamming into it after he dove overboard. Just poppin' ideas. Here's a couple of pics from the real shrimp boat that they used for the filming, "Miss Sherri" in Beaufort, SC.
Robert O
    January 2012
Posted by fright on Monday, March 25, 2019 11:10 AM
Put in some hours over the past week and worked on the hull and the cabin. There is another build of this shrimp boat being built by a very talented modeler, Don Stauffer. I liked how he built a floor and bulkhead to help 'hide' the empty hole that is left inside the cabin. By the way, Don's bulkhead shows his talents! I borrowed his idea of adding a floor and bulkhead and I just kept adding other things. Had I thought ahead, I would have filled and sanded the mold marks of the inside walls.
I used a computer cable's plastic packaging to creat my stove. I only added a tiny piece of round Evergreen for the vent. I also made a bed and the table out of Evergreen scrapes. My wife reduced a map of the Louisiana coastline which I mounted on plastic and glued to the bulkhead. I had a metal stack of bags whcih I painted and placed in one corner. Glued and painted a piece of paper towel that I cut in the shape of a slicker and glued that to one wall. I was not planning on using any lighting but, unless I add a LED to the inside, none of this will be seen.
I taped and painted the lower part of the hull with red oxide. I also sponged on some dark gray paint to the springer rail of the hull. After all was dry, I added some more grime to the hull and along some of the scuppers. I made a paper stencil of Jenny nameplate and used a glue stick to adhere it to my sheet of Evergreen. After cutting out my shapes, I made a pencil stencil to transfer JENNY onto the plastic. I then painted flat black with tiny brush. I punched a hole on each end and inserted a small nail. I cut off the nail shaft flush to the pastic and glued my nameplates on each side of the bow. The main hatch cover was painted with two shades of brown, than lightly sanded, and given a grayish wash. I used three pieces of square Evergreen to recreate the tubular wheel housing that Forest is seen standing just aft of the main hatch.
So here are pictures of my progress:
Robert O
    December 2003
Posted by scottrc on Monday, March 25, 2019 11:21 AM
Robert,
I smell the scent of dead fish, rotten paint, stale salt water, and diesel fuel just looking at her.
Nice effects!
Scott
    January 2012
Posted by fright on Monday, March 25, 2019 12:06 PM
As Forest would probably have said, "That's a good thang"
Robert O
    June 2014
Posted by Tanker - Builder on Friday, March 29, 2019 10:37 AM
Hi!
 I radioed mine .That was easy and plus the strips of batteries were ballast . She sailed nice and I was able to do all the detail too . T.B. P.S. I had to enlarge the prop and rudder to get Scale performance though .
    January 2012
Posted by fright on Wednesday, February 26, 2020 6:29 PM
Finally - back at it working on my 'Jenny' shrimp boat. I changed a couple of things with the interior cabin's bed. For the deck, I drilled an opening into the engine exhuast funnel to add realism; put together the winch system (the instructions are very vague with this part); and added the Sampson post to the forward deck. I did a trial run at night with a 3v Pico warm white LED to check illumination.
Great - I am unable to post any pictures. If anyone can help me out, I'll add them to my post. Many thanks for any help!
OK. Back in business. Figured out how to post pics!
Robert O
    October 2019
Posted by Tanker-Builder on Sunday, March 1, 2020 11:25 AM
Hi;
      I went back over the photo from the movie. It looks like the Bulwarks had been modified or removed in some areas. I could be wrong.
    October 2019
Posted by Tanker-Builder on Sunday, March 1, 2020 11:27 AM
Hi Again!
    I was re-examning your photos of the cabin's inards. Got a very important queation of a critical piece of gear. Where's the head?
    January 2012
Posted by fright on Sunday, March 1, 2020 7:11 PM
Tanker-Builder.
To qoute a famous line from the movie, "Stupid is as stupid does". LOL I totally forgot about human neccessities! The good thing is, none of the interior is really visible thru the windows of the cabin. I just did not wish to leave a giant opening into the hull under thhe cabin.
Here is a photo from the movie. She did have her bulwarks. They created a new steering rig just aft of the main hatch for easier filming of Forest at the wheel.
Robert O
    October 2019
Posted by Tanker-Builder on Monday, March 2, 2020 9:00 AM
Okay!
      I see where I got that idea. It was a matter of shading in the photo.
    January 2012
Posted by fright on Monday, March 2, 2020 9:07 AM
Got a lot of work in over the weekend on my Jenny shrimp boat. Added the 2nd cabin door (it still needs to have the gaps filled in and painted. I removed the frame from the life preserver and hung it higher up on the cabin along with spare rope (which hides the original hole for the placement of preserver). In the movie, the Jenny has a circulating air fan in the cabin's roof. I used a 3mm chrome bead attached to a painted toothpick. (My wife's idea and bead!). On the Jenny used in the movie, the exhaust vent sits atop a small storage locker with door. I made my locker from styrene sheet and cut bottom off of exhaust vent.I then glued it to a thinner styrene square and glued to the top of locker.  It now looks accurate to the Jenny from the movie. I also added some sludge and fish blood stains to the rear of the deck. No working boat is accurate without fish blood! I am now working on creating the aft steering gear. She's comin' 'round.
Robert O
    July 2014
Posted by Bakster on Monday, March 2, 2020 9:29 AM
This is a fun build and you are making nice work of it. I'd subcribe to this thread if I thought it would work to do so.  I'll keep an eye out for updates.
Keep up the good work..
    January 2012
Posted by fright on Monday, March 2, 2020 9:45 AM
Many thanks Baxter for your comment and taking a look. I'm having a good time modifying this Lindberg kit. Every kit is a good learning curve for someone like myself.
Robert O
    April 2010
Posted by Theuns on Monday, March 2, 2020 9:52 AM
" Shrimp BBQ, shrimp saurte, boil it, fry it, shrimp and potatoes, shrimp stew, shrimp salad, shrimp and corn, shrimp sandwitch....thats abot it " LOL
Theuns
    January 2012
Posted by fright on Monday, March 2, 2020 10:19 AM
Theuns - LOL  Cheers!
Robert O
Posted by Don Stauffer on Tuesday, March 3, 2020 9:10 AM
Looking great!
    January 2012
Posted by fright on Tuesday, March 3, 2020 12:17 PM
Thank you Don Stauffer for taking a look. I was inspired by your work on your shrimp boat and your interior cabin work that you did. Even though it's almost impossible to see inside once the top  of cabin is added, it sure beats leaving that big hole in the hull.
Your models always look fantastic! I've mentioneed you a couple of times in my posts on your model. For an inexpensive kit, this model has a lot to offer. Not the best fitting parts but with some work, they finish well.
I looked at your shrimp boat several times when it came to putting together the winch. The instructions were really vague. Once again, I want to aknowledge your work and thank many of the other modelers for inspiring and helping others to improve their skills. Toast
Robert O
    January 2012
Posted by fright on Sunday, March 15, 2020 5:21 PM
Robert O
    January 2012
Posted by fright on Thursday, March 19, 2020 7:21 PM
I've started in on getting the mast, boom and stern tubular support ladder ready for instalation on the deck. I've drilled a couple of holes near the ends of the outriggers where I can attach a block. Painted black with a slight wash of brown and steel for the fittings.
For the Try Net boom, I added a crossbar that is on the Jenny. Crossbar was made from sanding down a piece of sprue from the kit. I drilled two holes and attached a couple of small eye hooks on the crossbar. The eyehooks were made by placing a sewing needle in a vise and wrapping anodized wire tightly around the needle to for an eye. Color scheme is the same as Mast.
In the movie, the Jenny has a tubular type of ladder that mounts to the stern bullwark and attaches to the crossbar by means of a shackle.(?)  I scratch built the ladder using Evergreen styrene plastic round and glued the pieces together on a sheet of glass. I then used a single edge blade to pop it free after drying. Again, same colors used.
The spreader doors in the kit are plain of any detail on the backsides. Seeing how they represent wood, I used the backside of my blade to etch in some horizontal lines. I then painted a coat of grey, followed by two Burnt Sienna washes for difference in color. Paint is all acyllic.
Robert O
    September 2012
Posted by GMorrison on Thursday, March 19, 2020 8:36 PM
fright
No reason why you can't make the top of the cabin removable.
My purse seiner is set up that way.
Bill
