Artwox Wood Decks-Couple of Questions
Posted by Tojo72 on Monday, April 6, 2020 8:00 PM
I am getting ready to install some of the decking for the first time,all of the raised deck housings and protrusions are painted,all holes on wood deck are punched out.Is the adhesive on the wood deck good enough or do I add more,once the deck is in place do I seal it with a clear coat,gloss or flat,acrylic,lacquer,or enamel,does it matter.
Also any other tips appreciated
    October 2019
Posted by Rick Sr on Monday, April 6, 2020 9:00 PM
I am not familiar with Artwox decks but the Scale Decks I used were sprayed with Testors Dull Coat (why would you want shiny and thus slippery decks on a ship?
I used Gorilla Glue to fasten the Scale Decks down. It allows you time to position the deck.
I
    September 2012
Posted by GMorrison on Monday, April 6, 2020 9:02 PM
You are stuck (ok I mean have to use) the adhesive that's there.
Stain before install, but DON'T use anything water based. Stick to spirit based or enamels.
Test fit the thing and enlarge holes if needed. Never rely on the adhsive to hold it down; treat it as though it would lie flat on it's own.
Posted by Tojo72 on Monday, April 6, 2020 9:13 PM
GMorrison
Stain ?? Do you mean only if I need to change the color of the deck,I mean the color looks okay to me ?
Could you clarify that second statement not understanding it.
Thanks for your attention.
Posted by Bish on Tuesday, April 7, 2020 6:02 AM
I'm useing an Artwox deck for the first time on my S-100. I have only added a couple of pieces so far but they have stuck down well without any extra glue.
I never thought about staining those bits, will have to do that for the reast.
    September 2012
Posted by GMorrison on Tuesday, April 7, 2020 10:13 AM
Tojo72
GMorrison
It depends on what your model is, Tojo. I apologize for not being able to remember.  Is the Artwox piece untreated wood? That would be a peacetime condition. Or weathered natural in some cases.
I use a Cabot stain called "Driftwood". It just makes the deck a little gray, it looks slightly weathered.
Of course your model.
Wood decks expand and contract, and easily buckle. Often the fit to the plastic kit is good in some places and not so much in others. I've found the problem areas tend to be between objects, like two adjacent turret bases. It's not workable to force down the deck in the space and count on the adhesive to hold.
If possible, lay the deck down without pressing on it and check the fit. It should be a little bit loose. If not trim the openings in places that aren't too obvious unti it drops on without pressue.
Bill
    July 2014
Posted by Nino on Tuesday, April 7, 2020 10:54 AM
     My experience with Artwox was good. Fit has been acceptable and as GM says, make sure it drops in place without binding.  On one model, the IJN Yamashiro, the deck was a bit short (.2mm?) on the stbd side at just 1 point.  After a few years I noticed one small edge of the port side was lifting up.  I attribute that to too much humidity in the house and my fingers contact with the adhesive during application.  I glued the edge back down with some brand X glue-everything stuff. The deck is holding firm so far.       I also bought a de-humidifier.
 Summary:  The self-stick deck worked for me.  One important point... decks with too much wood surface detail , like raised lines, need some scraping to make them flat for the best contact.
       Nino
Posted by Tojo72 on Tuesday, April 7, 2020 10:59 AM
Here are the first two pieces I did.It is for Trumpeters 1/350 Graf Spee,I like the color,just going to use a flat non acrylic clear to seal it.It went on pretty easy and I like the look.
Thanks for the info guys
    September 2012
Posted by GMorrison on Tuesday, April 7, 2020 11:32 AM
Well that looks nice. Thanks for identifying the ship. I agree that would be a good subject for ***-and-span.
