Need Help With Kearsarge Build.
    April 2016
Posted by RacerToo on Monday, February 22, 2021 9:51 PM
  I need a little help. I'm currently building an early version of the USS Kearsarge and to be honest, I know very little about sailing ships. I'm trying to get an understanding of how the chain relates to the capstan. I've seen many variations of the location of the chain cover/guard on models so I'm a bit confused as to where to mount it. Any help would be much appreciated. Photos would be a plus. Thanks.  capstan by steve hawley, on Flickr" alt="" />
  Left Foot by steve hawley, on Flickr" alt="" />capstan by steve hawley, on Flickr
    September 2012
Posted by GMorrison on Monday, February 22, 2021 11:27 PM
I'm not that familiar with Kearsarge, but photos like yours indicate that the anchor-capstan set up was typical of sailing ships of the 19th Century.
The anchor chain ran up into the ship through a hawse hole that led to a hawse pipe. The chain in this case came up into daylight, under the little forecastle deck, onto the main deck and ran back to a fitting called a spurling. That is the part you drew arrows around. Where those were located is beyond my knowledge, but close to centerline makes sense as they had to pass through the deck below to get to the lockers, and those would be side-by-side.
Passing into the spurling, it would run down a pipe called either a spurling pipe or a chain pipe where it fell into the chain locker.
The chain(s) never got close to the capstan. The capstan pulled on a stout loop of rope called a messenger. That had a number of turns around the capstan and usually ran forward and looped loosely around a bollard or post that kept it positioned fore and aft. It also lays at the feet of those gentlemen in the photo.
The strain of the capstan messenger is transferred to the anchor chain by nips or nippers, usually short pieces of line that are used to lash the messenger to the chain as it comes aboard and removed at a point where the chain and messenger diverge in direction.
Once fully weighed, the anchor chain is secured with a stopper, a short length of stout rope or iron bar with a hook on each end. One end is attached to the anchor chain and the other to an eye attached to a stout timber on the ship.
As for Kearsarge, as I said, my knowledge is minimal. I hope that helps.
Bill
    April 2016
Posted by RacerToo on Tuesday, February 23, 2021 1:59 PM
Thanks for that Bill. You're a wealth of information. I'm glad to see someone is here to take over for Prof Tilley. He was always great at giving detailed info to all modelers questions.
