Stupid? Nah!
    October 2019
Stupid? Nah!
Posted by Tanker-Builder on Wednesday, May 5, 2021 3:20 PM
Okay there's this;
    You are chafing at the bit to do something different. Paper/Card, isn't on the list. Neither is the more costly resin kits. What to do? Question, Does the Civil war interest you? So here's an idea. There was a boat. Well, a series of them that existed around that time that were considered way to far out for the saner fighting men in the C.S.A to deal with.
    Enter the " Davids". What were they? How about this description. To quote the Authors Brian Hicks and Schuyler Kropf from  the "Raising the Hunley" Book. From Page 42. "They were cigar shaped, made of wood covered with sheet Iron. Their bows came to a point where a long Iron spar was attached for where the torpedo warhead was attached.They resembled an overturned boat with a smoke stack sticking out of it. Unlike the submarine they had the luxury of Steam Power.
    Now like the "Hunley" this would be a very easy project. You go to H.L and buy a plastic tube( Clear ) of animals. They have them hanging around. They also contain Little Green Men( Soldiers) Cowboys and Indians etc. There's the hull! Got to the model rockets and buy two nose cones. There's the ends. Now use your imagination and greeblies for the rest. A two bladed, very crude prop, and single rudder under the centerline. No conning tower. just a pair of fairwaters alongside the hatch on the top. Clear tube. You can do the interior,   (One level) slide it in from one end and finish her up. Then you'll have nothing else no one has. A " David", By the Way, They did sink and damage Union ships BEFORE the Hunley.
    Or take and pinch your tube to shape it under hot water then cut out one side and build the " Hunley" There's enough photos and drawings available to do the job. Go ahead, Challenge yourself. You'll have on display something few have. PLUS, you will have somethinbg that costs way less than a Resin example. Without the stink of resin sanding!
    May 2011
Posted by Real G on Thursday, May 6, 2021 1:26 PM
TB, there are resin kits of the David out there.  Being the kind of person I am, I have a 1/72 example in the stash.  When I built the 1/32 Verlinden Hunley, I was surprised that there were so many sub and semi-sub designs built during the Civil War.  The neat thing about them is that, as you mentioned, they are comprised of relatively simple shapes and would be straightforward to scratch.  I might have a go with a larger 1/32 or 1/35 David in the future.
“Ya ya ya, unicorn papoi!”
    March 2008
Posted by Caveman on Thursday, May 6, 2021 6:46 PM
And don't forget the added incentive of a bunch of little green men to play with!
    October 2019
Posted by Tanker-Builder on Sunday, May 9, 2021 7:34 AM
RealG and Caveman;
     RealG, I actually didn't know about the resin Davids. I did know about the resin Hunley. Remember I an allergic to the dust from resin. I would like to see Injection molded kits of Both in the same scale.
   Caveman , I give those little soldiers to my neighbor's special needs boy. He has Spinal Bifida. But geez is he a tactician, He beats me at Chess about three out of five times a week. He is rare too, He actually has made it to TEN years old.
    May 2011
Posted by Real G on Sunday, May 9, 2021 1:45 PM
TB,
I wholeheartedly agree with you that injection molded kits of Civil War era subs / semi-subs / ironclads are needed.  I bought the Hunley because a friend built the USS Keokuk, which looked like some kind of steam punk iron turtle.
The real Hunley had a taste for blood, as it killed its first two sets of crew, including its designer on the second round.  My kit also had a blood lust - I was sawing the huge casting block keel in the laundry sink, using soap water to rinse off and keep the resin dust down.  I got impatient, took a big blade, and tried to slice the remaining excess off.  The soap made things slippery, so whoops, and the keel shattered off a long sharp shard, which promptly sliced across my hand.
It bled furiously, with that deep, dark red.  Plus it hurt like a son of a gun!  The kit and the laundry tub were spattered with blood.  After I cleaned off the cut, I stuck a piece of gauze on the wound and used masking tape to temporarily control the bleeding while I finished the job.  Hee hee I was so hard core back then.
I have actually gone right back at a kit after a knife mishap on numerous occasions, but the Hunley drew the most blood.
    October 2019
Posted by Tanker-Builder on Sunday, May 9, 2021 5:34 PM
Well:
 Next time use a sharper knife! remember the old saying."You get nastier, deeper cuts with a dull knife!" My grandma liked to bend the old sayings to suit her!
