Dapper Tom by Model Shipways
    March 2020
Posted by Having-fun on Saturday, December 11, 2021 12:27 PM
Well, I am back, I have not made an entry since finished the Black Pearl. I went looking for a new ship to built and I went after a ship that supposedly was for beguines, after doing some research I settle on the Dapper Tom by Model Shipways, scale of 5/32 to one inch.
Well, the ship itself, a model with a solid hull, was not to difficult, were I had the problem was with the very vague instructions, the writer showed his knowledge of nautical terms by using those terms for everything. Now, I supposed to be a beginner, which means, that I hardly know any nautical terms. The writer apparently realized this and buried in the text recommended to buy another book ( Also published by Model Shipways) that had an index of nautical terms, I purchased the book and did not help much.
As I say I found the instruction a bit vague, every time I try to do something I would expend a considerably amount of time trying to figure out what I was supposed to do next.
The member of this blog may say that is part of the fun, and that is a way to learn to built the ship, you may be wright, but, the way I see it, I purchased a “beginner's” model and for this reason, the instructions should have been written in a more detailed and cleared way.
Following there are 3 photos of the finish boat.
Front of shipFront of ship
Front of ship2
Fron top
Now I am looking for do another ship, I am looking a Columbus's ship: La Nina, La Santa Maria, and La Pinta, I also looking at the Bounty. All these model are made by Artesania Latina, I have looked at photos of their instructions and they appear to be fairly good. There 2 things I am looking in particular, scale, I want a ship were the scale is sufficiently large so I can reduce the amount of small parts as possible, at my age, my eyes and hands are not as good as they used to be, and second, a set of reasonable detailed instructions that can be follow.
I will welcome and greatly appreciated any recommendations you are willing to provide. Well, this rant is getting to long so I say bye.
Joe
Posted by CapnMac82 on Sunday, December 12, 2021 1:20 PM
Having-fun
Sadly, the AL (hich many o us reer to as "Artist in the Latrine") kits are neither simple to build nor entirely accurate for scale.  The instructions, also, leave a great deal to be desired.
The Amati Colobian ships probably fit your agenda better, generously scaled and reasonably good instructions.  Check out Olha Batchvarov on Youtue who does a masterful job on Piñta.  Playlist here:  https://www.youtube.com/playlist?list=PL2yU7nOqNxV-IE_K3eWvI5XAohRNWuHHT
Now, the Columbian ships are a pig in a poke, too.  There are no "authentic" plans for any of the nine vessels Cristoforo took to the new world in his several trips.  Most of what we know about the rigging is infered from other vessels, many coming from far later in history.  So, you want to approach them as "fun" rather than as "fidelity" to history.
Now, of "to scale" and "to history" the more modern Model Shipways and BlueJacket kits are far better.  Many of those feature Practicum in either booklet or DVD (or both) format.  With some precise step-by-step instructions.
The later kits with their actual frame style construction are superb--if more than a passel of work.  The 3/16" scale MS POB kits can be quite good, too.  If needing a whole toolbox of skills.
Solid hull kits are often deceptive, too, to the novice.  They are seldom "fully finished" and typically need detailed and precise work to finish them (Bluejacket's Constitution being a classic example of a solid hull needing rather a lot of finish work).
And, sadly, more than a passing amount of naval jargon is required for these kits.  There are just too many "sticky out things" and "pooched out/in bits" to not need to get specific.  A deadeye and a bullseye are unique and separate things (if similar in appearance when in small scale).  Knowing the difference between a "floor" and a "ceiling" is pretty important, too.
All just part of the process.
    September 2012
Posted by GMorrison on Monday, December 13, 2021 9:38 AM
An indispensable tool for the beginner is a little book called the Neophyte Shipmodellers Jjackstay.
https://www.amazon.com/Neophyte-Shipmodellers-Jackstay-George-Campbell/dp/B0007E9G0E
Pick one up for less than $ 10.
That Dapper Tom came out well. I have been building a stash of ols yellow box Ms kits. they can be found on ebay for about 1/2- 1/3 what they originally cost.
Bill
    March 2020
Posted by Having-fun on Sunday, December 19, 2021 8:58 AM
CapnMax82  thank you for your recommendation about the La Pinta model and Artesania Latina, it is to bad that I read your post to late, by the time I read your comments I had already ordered La Pinta from Artesania Latina, if I had read your comment before, I probably would have ordered the model from Amati.
I am starting a build log of La Pinta, let us see how it goes.
Thanks Joe
fox
    January 2007
Posted by fox on Sunday, December 19, 2021 12:19 PM
Many, many years ago I built an "Artist in the Latrine" model of the Scottish Maid (my avatar). It was a very difficult model to build. It took a long time to complete as it went on and off the shelf of doom many times. My main problem was caused by my carelessness. The plans were laid out on the floor of the room I used then as a workroom. I left the door open by mistake and one of the cats went in and made them almost totally useless. Could not get a replacement from them but I was lucky that a member of the forum had a set from one that he built and sent them to me. A rough idea of what it was like to build it comes from the wife. She said "I never heard that kind of language come from him and so often from his workroom. It's a good thing he kept the door closed."
It was built OOB and it looks OK for what it is. Here's a pic or two of the build.
https://photos.app.goo.gl/zgwiGHdpKcujPX1R7
Lots of members here know tons more about these ships than I will ever know. Listen to their advice as it will save you a lot of headaches in the future.
Good luck with your build. I'll be following along with everyone else.
Jim Captain
Stay Safe.
 Main WIP:
Posted by CapnMac82 on Sunday, December 19, 2021 1:40 PM
fox
It does indeed.  I think many of us, of a similar time frame, who went down the road for wooden ship kits started with Scottish Maid.
And, it's an interesting road.  Scottish Maid was an actual ship, and as-built plans of her exist.  AL's representation is decent, if in a 75% sort of way.  In much the way that a Hurricane resembles a Spitfire sort of way.
After the fact, what I determined was that, for the same effort the kit required, I could have just scratch-built.  Especially after replacing so many of the parts--either from re-working ones that didn't work.
One of the key things an AL kit will teach a person is that you absolutely, positively, must taper planks.  And, that task is as much art as science.
fox
    January 2007
Posted by fox on Sunday, December 19, 2021 4:02 PM
Amen to that Capt.!
Jim Captain
Stay Safe.
 Main WIP:
    March 2020
Posted by Having-fun on Saturday, December 25, 2021 10:53 AM
GMorrison
Bill
You say that I should be able to pick up this book for about $10, but, aparently Amazon was not notified of this, because they are asking $650 for the book.
Joe
    July 2011
Posted by MJames70 on Saturday, December 25, 2021 11:38 AM
Having-fun
GMorrison
Bill
Joe
There's at least ten on eBay in the $10-$25 range. Don't go by Amazon Tongue Tied
    September 2012
Posted by GMorrison on Saturday, December 25, 2021 5:13 PM
Having-fun
GMorrison
Bill
Joe
Theres a few in that link for $4 or $5 plus $4 shipping. You don't need a new one.
Bill
