Lighting Kit
    June 2016
Lighting Kit
Posted by David from PA on Thursday, February 16, 2023 7:59 AM
Hi. I'm building a 1/350 WW2  Essex class aircraft carrier and I would like to light the hangar deck by placing a lighting kit on the underside of the flight deck. Could you tell me what kind/size/voltage kit to purchase?
David From PA
    April 2004
Posted by Jon_a_its on Thursday, February 16, 2023 8:17 AM
David from PA
I know of lighting (+ engines + engine noise) kits for Jet and Prop aircraft, but I don't know of any specific kits for boats.
If you lean towards the experimental/proof of concept/el-cheapo end of the market...
I've used $/£/€ Store sets of christmas lights, run on 2 1.5V AA Batteries, available as warm white or multi-coloured sets.
Otherwise aim for 3V LED's & be prepared to do a lot of research, viz, I had a fancy to light up a B17F... 26 visible lights, excluding the instruments...
East Mids Model Club 32nd Annual Show 2nd April 2023
 http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
    May 2009
Posted by Pawel on Thursday, February 16, 2023 11:05 AM
Using LEDs is not very hard... If you buy the electronic components to do it yourself, it's also a lot cheaper than this "lighting kit" you're trying to find.
Here's what I managed to do:
Parts - some $10 in total:
Soldering:
Testing:
And on a finished model - please note that it's powered from a 5V USB power source - like the one used to charge your phone.
If you want I can try to give you some tips for the design, if you ned them.
Good luck with your build and have a nice day
Paweł
www.vietnam.net.pl
    April 2009
Posted by Cadet Chuck on Thursday, February 16, 2023 11:46 AM
Here is a great source for LED's, Miniature switches, etc.  I have dealt with them several times and received excellent service.
https://evandesigns.com/
    September 2012
Posted by GMorrison on Thursday, February 16, 2023 12:26 PM
What will be difficult is catching any and all light leaks. The ship only has the one elevator on the outside, but there are no doubt a lot of joints in the kit.
Posted by keavdog on Thursday, February 16, 2023 12:45 PM
Thanks,
John
    February 2015
Posted by InternationalRescue on Monday, February 20, 2023 4:08 PM
I echo Cadet Chuck on Evan Designs.  Their products are excellent and they are very helpful; also stand behind their products.  They have quite a gallery highlighting how customers have used their LED's; might inspire how to use.  Good luck with your build!
