USS St Louis Free 3D design files From World of Warships
    January 2021
Posted by JoeSMG on Thursday, March 2, 2023 6:59 AM
One of my favorite ships to play in WOW, the St Louis has been turned into a printable batch of files and offered for free as a game promotion on Printables.com: Printables WOW USS St Louis
WOW USS St Louis
If you go to the download page they have a ton of user builds posted and it looks like it prints really well across a wide range of filament printers. A ton of effort was obviously put into parting out the ship and arranging the pieces so no supports would be needed.
I'm sure the files could be made to also work with resin printers but the default scale and detail level seems geared towards FDM printers
The only thing I'm not crazy about is the very strict (and common) licensing terms. But if you just want an awesome, steam-punky ship design that has been made with ease of printing in mind, to try and 3D print for your collection, you can't go too far wrong with this free model.
- Joe the SMG
    January 2021
Posted by PFJN2 on Thursday, March 2, 2023 3:37 PM
Hi
Thanks for the link.
Pat
    December 2003
Posted by scottrc on Friday, March 10, 2023 2:08 PM
Looks like fun, I'll check it out.
Posted by Lufbery on Friday, March 10, 2023 6:55 PM
That's pretty awesome! Now to get a 3D printer . . .
So, what is an FDM printer?
Just an observation: unless my math is off, it looks like the scale is 1:162.5
That's a pretty big model: nearly 3 feet long!
-Drew
Build what you like; like what you build.
Posted by CapnMac82 on Saturday, March 11, 2023 12:20 PM
Lufbery
Fused Deposition Modeler (see also FFF, Fused Filament Fabrication) printing uses an "element" (looks like a string) fed to a printer head which brings the filament to its "melting" temperature and lays that element down in a series of layers.
This is in contrast to STL, Stereo Lithography, where a laser or similar collemated light source is used to "fix" liquid resin into fused particles.  (This is similar to Laser Sintering, where flaked or granulated particles--e.g. "sinters"--are fused together by the laser into a whole.)
"Filament printers" are generally less expensive to purchase, but the material cost of the various kinds of filaments can be as daunting as buying ink for inkjext printers.  Their printing ability is based on the size of the printing plate, and the vertical rise of either the print head or the plate.
"Resin printers" tend to be a bit more expensive to start, and are limited by the size of "the tank" of liquid resin for x-y, and the stroke of the z axis on the printer.
The liquid resin printers typically have an order of magnitude more "fineness" in their prints, as that is controled by the diameter of the intersection of the collemated light beams, rather than a heated nozzle.
Both will have "layer grain" but to different degrees.
Cost of the liquid resin can be steep.  And it can have a limited shelf life, unlike FDM filament.  Also, liquid resin prints need to be washed (typically) after printing, and want a UV light bath in a "curing tank" after the washing.  This can represent a cost overhead beyond the printer (and the desktop footprint can vex, too).
A person can work the edges of the lower-cost options in all of these.  But, it winds up being a bit like getting an airbrush.  You can start out cheap, but wind up spending more for better equipment later.  The parallels of canned air, air tanks, compressor(s) are also apt.
    January 2021
Posted by PFJN2 on Saturday, March 11, 2023 7:08 PM
Lufbery
Hi,
I have the worst time with trying to figure out the scale used in some 3D models.  For this one, when I pull the whole hull section into either Meshmixer or Chitubox (which is a program that I use to prepare the model for printing) it shows that the whole hull has the following dimensions;
L - 517.36mm
B - 80.94 mm
D - 63.29 mm
Looking at Wikipedia for the C-20 USS St Louis it lists the following dimensions;
L (overall) - 426.5 ft or 130.0m
B - 66ft or 20m
D - not listed
As such a 130m long ship would be 130,000 mm long, and dividing the model length of 517.36mm by 130,000 mm gives me a scale of about 1/251 scale.  Doing the same for the beam gives 80.94mm/20,000mm or about 1/247.  As such, my estimation is the the model is probably about 1/250 scale, as the dimensions listed inWikipedia may be scantling dimesions, not including plating or any other minor protuberances, while the model is molded with things like fittings and armor plating sticking off the sides etc.
However, I am not sure whether the programs that I am using may have tried to internally convert the files from metric to imperial or something like that.  Out of curiousity how did you come up with your estimate of 1/162.5?
Regards
Pat
    January 2021
Posted by JoeSMG on Sunday, March 12, 2023 9:36 AM
One thing I find interesting - the download page has links to about 150 pictures of user builds. And while some of them are quite good not one builder had even tried to fill the fairly obvious hull joint gaps before painting (many are not painted) . For sure there are some very clever 3D printing tricks employed - like switching filament colors mid print and using cool metallic filaments and multiple colors for different parts. But of all those builds, I don't think one was done by a truly serious modeler. They definitely seem more focused on printing technics than modeling technics - which I guess is understandable.
Another thing about the user build pics - Some display exceptional print quality - I wish they mentioned the printer used.
- Joe the SMG
Posted by Lufbery on Sunday, March 12, 2023 2:00 PM
CapnMac82, thank you for the detailed reply! I did notice the layering is some of the build photos.
-Drew
Posted by Lufbery on Sunday, March 12, 2023 2:09 PM
PFJN2
Regards
Pat
Hi Pat,
The download document shows the model as being 80cm long. I got the same overall length of 130 m that you did when I looked at Wikipedia for the real ship.
130m = 13,000cm
So, 13,000cm divided by 80cm = 162.5. One CM on the model represents 162.5 of the real ship.
Just to double check because math isn't my strong suit, I checked this site: Scale Calculator - Online Scale Converter
I got the same scale.
I guess it would be possible to print at some smaller percentage of the full-sized plans to get to 1:350 scale (for example), but I wonder if there is a limit to how well the printers work at those smaller scales.
Regards,
-Drew
    January 2021
Posted by JoeSMG on Sunday, March 12, 2023 2:59 PM
Lufbery
Yes indeed there is! That was the first lesson learned with my first prints on my first FDM printer. Ended up with what looked like spaghetti trying to print details far too fine for the machine. I've found for ship models, around 1/160 is the smallest scale that can reliably print rails and other fine detail, at least with an inexpensive home FDM printer. And even then they need to be slightly beefier then they would be in real life.
- Joe the SMG
    January 2021
Posted by PFJN2 on Sunday, March 12, 2023 5:41 PM
Lufbery
PFJN2
Regards
Pat
Hi Pat,
130m = 13,000cm
Regards,
Hi,
Thanks for your response.  In looking closer at the files it looks like the full hull model and the individual pieces may not be to the same scale.  Specifically, as I noted in my previous post the full hull file shows up as 517.36mm, but when I pull up all the individual pieces I get;
Part A (The Bow)  - 176.79 mm
Part B (ForeDeck) - 176.80 mm
Part C (Midships)  - 148.80 mm
Part D (Aft Area)  - 162.72 mm
Part E (Stern)      - 162.67 mm
Total Length - 827.78 mm
Dividing this by 130,000 mm full scale length gives a scale of about 1/157.
Similarly taking the width of Part C of 129.51 mm and dividing by 66 ft (20,117 mm) for the full scale beam gives a scale of about 1/155.
Regards
Pat
Posted by CapnMac82 on Sunday, March 12, 2023 6:52 PM
JoeSMG
Note that most printers will require "supports" for things like rails, as you can't "print in air" reliably.  The printer will have a specification for its smallest extrusion.
I have found that you do not want to get too close to that minimum diminsion, as it can be hard to discern the difference between the meant part and its support.  Also, the print can get unpredictably fragile, too.  So, you have to be extra careful to not be too ham-fisted with the diagonal cutters freeing the part from the support.
There is a "dodge" in that you often can print rails and the like separately, rather than as part of the hull or larger part.
Many FDM printers--especially with economy models--will have, for lack of a betterword, "difficulties" rendering round objects parallel to the base plate.  It's very typical to cant objects in relation to the base plate, as this renders "round" better than "normal" to x/y/z.
That's from how a round surface presents to the printer.  A cylinder "normal" to the base plate will have one (typically) "bead" in contact.  The next "bead" is raised, infetesimally, on one or both sides of the first.  But, that next pass is very much in a molten state from how the printer is extruding the material.  But, without supports, the next pass is like to sag.  That persists until the top of the cylinder is printed.
So, what you get is an oval, and often an egg-shaped sort of oval, as the upper surface "prints" better than the bottom.  This can be worse as you close in on the minima for printing (finding your round railings looking rectangular is under-satisfying).
The tech is a marvel, without a doubt.  But, it's not a be-all-to-end-all.  There's going to be an excellent case for modelers to "model."  That PE and the like may still have a place in the 3d print world.
    January 2021
Posted by JoeSMG on Sunday, March 12, 2023 10:33 PM
Excellent write up CapnMac82. With my FDM printer I no longer print spheres and such in one piece exactly for the reasons you state. I'll cut the object in half and print the new flat sides down, then glue it back together. I use this approach on hulls and lots of other shapes, Hulls are cut in half at the water line and printed like the sphere. I definitely use the dodge for rails, with FDM they get printed separately, flat on the build plate, not as part of the ship and will need assembly to attach them.
It's one of reasons I liked this St Louise model, the designer's boast of "no supports needed" agrees with my approach, you'll get better results when you part up the design for best printing without supports and then assemble it like a traditional model. It's a lot more work to design, print and assemble this way but final product quality definitely improves.
Again this is true for inexpensive home FDM printers. More expensive dual head printers have been around for a while, one head has the PLA or ABS filament used to print your model while the other head has a water soluble filament used for the supports. In theory this should allow you the dream of the one shot print and done without the normal problems of removing the support material. I'd love to see how this works in practice.
- Joe the SMG
    January 2021
Posted by JoeSMG on Wednesday, April 12, 2023 6:16 PM
Youtube link to a (completed) work in progress video of this model by someone who knows what the're doing - Spoiler - it ain't me!
https://www.youtube.com/watch?v=SwYTyPFoBTc
- Joe the SMG
