Submarine video
    April 2023
Submarine video
Posted by John3M on Saturday, September 2, 2023 7:58 AM
I have a small collection of books on ww2 ships an submarines i found this video enlightening i would like opinions on its authenticity i learned a little i never knew. I was looking for the correct area to post this since i thought it should be under boats but i stand corrected
https://youtu.be/FctRpaleRFc?si=1iHeh6U1xqCCbl6j
    July 2003
  • From: On my kitchen counter top somewhere in central North Carolina.
Posted by disastermaster on Saturday, September 2, 2023 5:26 PM
Here'ya go....
First thing I caught.
At point 0:21.... incorrect rotation displayed
From the rear aspect the right one clockwise and the left one left turning counter-clockwise to neutralize the radial spin momentum.
Otherwise, a very informative link. Thanks.
Russian subs..... well, russian subs.... who knows.
Incorrect
 https://i.imgur.com/LjRRaV1.png
    April 2023
Posted by John3M on Saturday, September 2, 2023 5:57 PM
I got that slso with both rotating the same way it would be hard to stear
    July 2003
Posted by disastermaster on Saturday, September 2, 2023 6:38 PM
John3M
I got that slso with both rotating the same way it would be hard to steer
Posted by CapnMac82 on Sunday, September 3, 2023 12:09 PM
John3M
Not really.  Triple-screw ships all rotat the same direction.  Put two outboard motors on a boat, and they both go the same way.
Now, if you look at a rotating propeller, as very low RPM, the direction the screw is "rolling" in imparted on the vessel.
So, a single-screw RH prop, will want to "walk" the stern to the right (as observed from behind) when going ahead (this being all at the very edge of forward "bite").
A LH screw will "walk" the other way.  As will a RH screw turning in Reverse.
When backing, the blades are significantly less efficient, so the effect can be more pronounced.
This becomes a ship-handling skill for getting off--or on--piers & docks.
