I was afraid someone might ask that question......
Well I first looked at some pics of these in the water and then.... Not being very savey with ships and subs and because of the complex shape and sides it was not easy to just measure down and mark the waterline at the deck level ......so..... I filled the bathtub just enough so that the subs keel touched the bottom and that the waterline was right were I wanted it to look in my water scene....asking my lovely assistant ( my wife ) to hold the sub at the right angle....I marked along the sub were the water level was, then later I taped along the sides just about 1/4 inch below where I marked the water level...( to make up for mounting and the water 'stuff' )
AND THEN!!!!!
It was DREMEL TIME!!!
I used a couple thin dremel cut off wheels and WENT TO TOWN!!!.....boy what a mess! I had lotz of FUN!!!!
BUT!.....I kinda goofed.....somehow I got fixed on a mellow water scene....without giving much thought to how I want my ship to look in the waves and not leaving alot of room for having the nose up or a good tilt to one side...
So I'm probably going to put the very rear portion of the deck just a hair below the water and the nose as high as I can and cut a bit more off one side to give her some tilt.
.......and yes we had our clothes on! ....You should be ashamed of your selves!!
Straighten up and fly right.....
