Nimitz class carriers..
Posted by ipms40049 on Friday, October 1, 2004 4:53 AM
.. I want to convert my Trump. Nimitz into a modern carrier. Which one would be the same length as the Nimitz? And one that would take less modifications? I dont want to have to shorten the Nimitz hull any.
Pat Hensley Booneville, Ms "Thank you for being here and playing nice"...please do not drag sand outside the box ! CURRENT BUILD(s) Revell 1/72 U Boat VII C Tamiya Willys Jeep - for 2010 Nats Bronco's Staghound -for 2010 Nats Dragons M16 Multi gun carriage - for the 2020 Nats. LOL
Posted by Anonymous on Friday, October 1, 2004 12:36 PM
Do you mean you want to make the Trumpeter NIMITZ kit into another NIMITZ Class Carrier? All NIMITZ Class are roughly the same length. The one with "major" modifications is the USS RONALD REAGAN. This link might help you.
http://www.chinfo.navy.mil/navpalib/factfile/ships/ship-cv.html
    November 2003
Posted by Mike F6F on Friday, October 1, 2004 3:00 PM
Patrick,
The basic hull for all Nimitz-class ships, as far as modeling goes, would be the same. The changes are in the number and location of the sponsons, and the various hull cuts beneath the flight deck. The Nimitz class ships are having their bridle arrestors removed and no CVN since the T. Roosevelt CVN 71 has been built with any. (These are the extensions at the bow and angled deck at the ends of the catapults. They were once used to catch bridles that connected aircraft to the cats. No currrent Navy a/c uses them, so they have been removed.) The other major noticable difference is the configuration of the mast aft of the island. The newer ships have "solid " sides, the older ships showed the framework. As the ships are being refueled and overhauled the masts become "solid." Each island will have slightly different details too.
The Reagan has no after mast and a much different island structure. The flight deck only contains 3 arrestor cables, the other ships have 4.
The CHINFO link above is a very good place for CVN photos.
"Grumman on a Navy Airplane is like Sterling on Silver."
    November 2003
Posted by Mike F6F on Saturday, October 2, 2004 9:21 AM
Oops!
I forget to mention that the Reagan has a large bulbous bow that makes the hull different from the other ships in the Nimitz-class.
Posted by Anonymous on Saturday, October 2, 2004 1:16 PM
Mike,
With the arrival of the REAGAN, and the GEORGE BUSH (CVN-77) in a few years, it's almost that they are in a class by themselves. Don't forget that the REAGAN's angled flight deck also has an extra degree of angle so then can use both cats one and two to launch while recovering aircraft at the same time. Wait until CVX comes out...it'll be interesting to see.
Carl
Posted by Anonymous on Saturday, October 2, 2004 1:18 PM
Patrick,
I think you'll be pretty safe to build CVN-68 through 75 using the Trump kit, with the minor mods that Mike pointed out. To build the REAGAN will take a lot more modifiying.
Carl
