painting anchor chain?
    August 2004
Posted by four-star on Wednesday, November 17, 2004 7:49 AM
Hi, does anyone have any advice on blackening anchor chain? I have had to resort to cheap jewellry chain to get the right scale (21 links per inch), and so the chain is quite shiny. I was wondering how to get the chain black - I can't see paint working as I am sure that this will stick the links together, or the paint will chip where links come in contact. Thanks for any advice
Posted by Anonymous on Wednesday, November 17, 2004 8:56 AM
You could carefully mount them first then paint them.
    December 2014
Posted by bigjimslade on Wednesday, November 17, 2004 9:43 AM
There are chemicals available for blackening chain.
See www.micromark.com for example.
    May 2003
Posted by jtilley on Wednesday, November 17, 2004 11:54 AM
Stop by your local Wal-Mart's sporting goods department and pick up a bottle of gun blueing. It's pretty much the same stuff that the hobby shops sell. In any case, the effect will be better if you (1) clean the chain thoroughly first in either lacquer thinner or vinegar, and (2) spray it with some sort of flat finish as soon as it dries.
Incidentally, I assume the ship in question isn't British. The Royal Navy has a long tradition of painting its anchor chains white.
Good luck.
    August 2004
Posted by four-star on Thursday, November 18, 2004 6:12 AM
Thanks for the tips.
No, the ship isn't British, the chain is for the Tamiya 1/350 Bismarck modelSmile [:)].
Posted by rodc on Thursday, November 18, 2004 10:17 AM
Hey Bezics,
Not sure if this would work or not. Cheap jewller's chain such as you have is usually coated in a thin plating of paint to mimic gold or silver finish. I was wondering if you took some sort of torch such as propane or butane and heated the links under the direct flame would it tarnish and/or blacken the plating to get the desired effect. Of course, you would need to well wash the chain afterwards to ensure that any soot residue is removed.
Just food for thought!
RODC
Posted by Anonymous on Friday, November 19, 2004 1:20 PM
This is what I did a few times on many sizes of chain including very small link chain. I first measured out my chain for lengths and turns depending how it would be attached to the ship. I then took a cardboard box and mounted the chain with long straight pins on the 'side' of the box so I could get all the way around the chain and hold it in the configuration I needed. Keep the chain slack between the pins so that while brushing on the paint, the links move around some. That way you get in between where the links loop with each other. I then thinned down some flat black paint so it would not be so thick and painted the chain. It was dry enough after about an hour and a half to handle. I then removed it from the box and carefully touched up where the pins had made contact with the chain. The chain was still a little stiff from the paint but not near as stiff as when you use paint straight from the bottle. After letting it sit for a couple of hours more, it's ready to place on your ship with a minimum of repositioning. To mount it, I used Testor's Clear Parts Cement since it doesn't attack the plastic or the paint. I run a fine line where the chain will be and then lay the chain in place. I think my ships looked great but it took me a couple of practice runs to get the paint thickness right.
If you have an airbrush it's even easier. Hold the chain straight up and down and as you spray constantly raise and lower the chain onto a hard surface until it is completely covered. After your done spraying, do it 2 or 3 more times and your done. I did this on my last ship and it was the best. There was no stiffness and sticking of links together. The chain looked like it was bought that way.
Hope this helps.
Dale
    August 2004
Posted by four-star on Saturday, November 20, 2004 12:26 PM
Thanks
Hope this helps.
Dale
Can I just check - Are you suggesting painting the chain very gradually using very fine layers of paint here?
