BONDO, SPOTTING AND GLAZING PUTTY?
Posted by ipms40049 on Friday, January 10, 2003 6:43 AM
Whats this Bondo Spotting and Glazing Putty good for? Its that red stuff.
Pat Hensley Booneville, Ms "Thank you for being here and playing nice"...please do not drag sand outside the box ! CURRENT BUILD(s) Revell 1/72 U Boat VII C Tamiya Willys Jeep - for 2010 Nats Bronco's Staghound -for 2010 Nats Dragons M16 Multi gun carriage - for the 2020 Nats. LOL
Posted by Anonymous on Wednesday, January 29, 2003 10:23 AM
Yes it is red & it is very good to work with. you can sand on it dry or wet & it fills in great. I have used green putty before & still do but bondo is also very good
Posted by seaphoto on Friday, February 7, 2003 5:58 PM
There are plenty of putties out in the market place. I have had good luck with two:
3M acryl blue - this dries fast, and is my choice for filling small nicks where strength is not an issue. It feathers very well.
Evercoat Eurosoft - this is a catalyzed putty, which is mixed with a hardener to become actives. This stuff is wonderful - becomes hard enough to work with a razor blade in a couple of minutes, and sand in about 15 or so, depending on the temperature and how much hardener you add. It is good for corners or anywhere you need your putty to have strength. You will find a short article on my website on how to use it by following this link:
http://wmunderway.8m.com/cont/putty/putty.htm
Kurt Greiner
Warship Models Underway
www.warshipmodelsunderway.com
Kurt Greiner
Interested in large scale, radio control warships? http://www.warshipmodelsunderway.com
    August 2008
Posted by tankerbuilder on Tuesday, September 1, 2009 6:55 PM
 Hi again- ipms40049 : The stuff to which you refer is typically used to fill small scratches and flaws before painting a vehicle . The glazing putty(that,s it,s proper name )comes in red,green and a very light turquoise.3 M is the most common . "bondo" on the other hand is a filler putty that MUST use a cataylist. The common name is bondo, but, it comes in many brands and prices.Less than proffessional auto body shops will use more bondo than needed. Because it,s cheaper than a used or new fender etc. That,s why when you see a nice shiny car full of ripples, especially around an accent,or uneven lines on a body contour you can be sure it,s got more "bondo" than necessary in the repairs. I don,t recommend using "bondo" on any model that is RADIO CONTROLLED.If you do ,make sure its set for a week,in a very even temperature controlled environment. Then prime it with REAL AUTOMOTIVE PRIMER. Modelers primer,TAMIYA etc. are not water resistant as some would like.I hope this helps you on your project.    tankerbuilder
    September 2015
Posted by Aaronw on Tuesday, September 1, 2009 7:30 PM
I use the Bondo brand red glazing & spot putty all the time. I find it easier to use than Squadron or Testors putties and for the same price you get 2-3x the quantity.
The "Bondo" Tankerbuilder is refering to is the two part filler. Some people love the stuff but it definately has its quirks and can be difficult to work with if you don't have experience with it. Its main advantage is minimal shrinkage, so you can fill large voids. With putty you need to use scrap sprue or other solid material only using putty in thin layers over the top.
    August 2009
Posted by E Boat on Tuesday, September 1, 2009 7:58 PM
The Squadron putty dries waaay to fast in my opinion. It really shows it's faults when precision or confined spaces come into play, I need some work time.
I am going back to Bondo with at least 2-5 minutes before it goes hard or crumbly.
    August 2007
Posted by Reload on Saturday, December 5, 2009 8:05 PM
Where can I find the 3M glazzing putties? I can't find it anywhere. Am I blind or just not finding all the skittles leading to the right place?
Brent
1 VP - PPCLI 89-92 A Coy RED DEVILS
 I mean, I had fast motor cars and fast motor bikes, and when I wasn't crashing airplanes, I was crashing motor bikes. It's all part of the game. — Sir Harry Broadhurst, RAF, 12 victories WWII
    May 2003
Posted by qmiester on Sunday, December 6, 2009 3:47 PM
Just about any automotive supply store (NAPA etc) usually carries some form of Putty (either their own brand or something like Bondo or 3M brands).  Check out a hardware store or even Wally World's automotive section.
Quincy
    May 2008
Posted by ejhammer on Friday, December 11, 2009 9:01 AM
Got mine at NAPA. They had to order it from central warehouse but was only one day. 3-M Acryl-Blue glazing putty #051144-055964, 21 oz. tube, $28.00 including tax. Is a lifetime supply. I repackage it in to old paint bottles and gave some to guys at the modeling club.
EJ
Completed - 1/525 Round Two Lindberg repop of T2A tanker done as USS MATTAPONI, USS ESSEX 1/700 Hasegawa Dec 1942, USS Yorktown 1/700 Trumpeter 1943. In The Yards - USS ESSEX 1/700 Hasegawa 1945, USS ESSEX 1/700 Dragon 1944, USS ESSEX 1/700 Trumpeter 1945, USS ESSEX 1/540 Revell (vintage) 1962, USS ESSEX 1/350 Trumpeter 1942, USS ESSEX LHD-2 as commissioned, converted from USS Wasp kit Gallery Models. Plus 35 other plastic and wood ship kits.
    August 2006
Posted by HawkeyeHobbies on Friday, December 11, 2009 9:18 AM
One of the major drawbacks with using a dark colored putty/glaze is it necessitates the use of a primer to hide it when applying a light colored paint scheme. I like using the Acryl Blu because of its properties including its light color which covers even with white.
One of the issues many novice modelers have is they tend to trowel on copious quantities of fillers. More isn't better. If you have that large or deep of an area to fill, consider using scrap styrene to fill as much if not all of the void first, then finish off with a dab of putty. Remember that over time dissimilar materials will separate as they shrink and breakdown.
Gerald "Hawkeye" Voigt
    December 2005
Posted by viper_mp on Friday, December 11, 2009 1:15 PM
I have used the Bondo red glazing putty with good results.  My favorite putty remains the Kombi Automotive Spot putty.  I jsut cant find anywhere that sells it anymore.
Rob Folden
Secretary / Webmaster- IPMS Plastic Surgeons Member at Large-IPMS Hawkeye Modelers
