wood sealer again but better explained
Posted by Anonymous on Friday, December 24, 2004 2:49 AM
I appreciated the responses and made note of each one for future reference. My initial question, which I forgot to explain, is a simple way to seal wood yards that will be used on the 1\100 plastic HMS Victory. I was hoping to find a simple sealer that could be brushed or sprayed on and then, after it dried, could be painted over. I did the masts and yards on the Bonhomme Richard with Testor's Dullcote and even though they came out pretty good, I was hoping to get a bit smoother finish. If the only good way is the sandpaper and finish material, I'll do, but I am hoping that there are some other suggestions.
Also, I have a big can of polyeurathane (sp?) that I seem to have no use for. Can this be used along with the sandpaper and paint over it?
Thanks for being there when needed.
Dale
    May 2003
Posted by jtilley on Friday, December 24, 2004 8:28 AM
I imagine you're talking about painting the spars in question black. If I were you I think I'd start with either a sanding sealer (from the hobby shop's model airplane department) or a compatible wood primer (from the paint store). When it's dry, sand it with the finest sandpaper you can find, and you should be in good shape.
The polyurethane is a varnish, intended primarily as a finish coat. In a pinch it probably could be used as a primer (if sanded to give it a little "tooth"), but it's designed to give either a satin, semi-gloss, or high gloss finish to unpainted wood.
Hope this helps. Good luck.
