1/350th TITANIC light test!
Posted by Papa-Echo-64 on Saturday, January 8, 2005 12:42 PM
Here is the first LIGHT TEST for my 1/350th TITANIC!
There are two thumbnail images to click on and YEP! those are two 12" cold cathode lamps! and they are PERFECT for this project! you can get these on line from 5.00 to 20.00 on line....I found mine at Amazon.com.
Of course there are no window diffusing methods inplace yet.
ENJOY!
http://troysmodels.homestead.com/TITANICLIGHTSTEST.html
Straighten up and fly right.....
    December 2012
Posted by FreedomEagle1953 on Saturday, January 8, 2005 1:25 PM
Very cool ... Smile,Wink, & Grin [swg]
FreedomEagle1953
Chicago, IL area
"keep on building 'em ... but don't glue your fingers together"
Posted by Papa-Echo-64 on Saturday, January 8, 2005 3:53 PM
Thanks Steve! Smile [:)]
Posted by Anonymous on Sunday, January 9, 2005 2:41 PM
Greetings.
I built one of the Acedemy/Minicraft 350th Titanics for my dad about 10 years ago. I also put lights in it, and during that process, I played with a lot of different setups.
I finally settled on just 3 low voltage lights, in the hull only. Part of this was because wiring more of them into the upper decks was getting tedious (I tried), but ultimately, I abandoned them above the hull because of the way that the light bled through the plastic. I even went so far as to paint some of the interior (inside) walls black/other colors, and although it worked to block the light, masking off all the windows had added up to a really, REALLY big hassle. It wasn't worth it for me, so I settled for what I had.
Although I could have done more, I thought it looked good enough.
I'm also one of those that has a hard time completing kits because I'm always adding and adding and adding... And I get pretty indecisive sometimes when all the possibilities start spinning around in my head. Sometimes the best medicine for me is to just toss it together and not try to make the perfect model... One of the disadvantages of ADD, I suppose.
Best of luck.
Posted by djrost_2000 on Monday, January 10, 2005 1:48 AM
That's really neat! Almost eerie having it lighted in the dark.
Dave
Posted by Buddho on Monday, January 10, 2005 2:33 AM
That looks fantastic, alot of work must have gone in this one...
Regards, Dan
Posted by djmodels1999 on Monday, January 10, 2005 3:25 AM
Looking good!
Posted by Anonymous on Monday, January 10, 2005 1:01 PM
That looks brilliant, I've been thinking about the cold cathodes for my 1/400 Revell Titanic, I was only going to use one though, what do you think? Also are they the 12v auto cathodes you've used?
    September 2003
Posted by inpw1 on Monday, January 10, 2005 7:41 PM
Looks good, I knew I should have done something with all the potals I drilled out on the one I did for the Father-in-Law.
jim
    September 2003
Posted by inpw1 on Wednesday, January 12, 2005 11:48 PM
hey Papa-echo do you know much about fiberoptics??? if you do I need yur help if could please be so kind.
emial me if you want so I can pick yur brain
jim
