I usually make water by drinking lots of ice tea before hand...
What?! Aw c'mon, someone had to take that one.... sorry.
![Blush [:I]](/FSM/CS/emoticons/icon_smile_blush.gif)
Anyway, the envirotex works great, so does 2 part Glaze Coat. The only thing with using resins is that self level. The problem comes when you make displacement wakes, ripples, chop or motor wakes. That usually requires some sort of sculpture of the surface.
Since you are doing a Nam pibber, brown is good. So it shouldn't matter what you use, anything from celuclay to resin will work. Maybe even a combination of the two. I would probobly paint it brown, then paint the wakes in a light cream or off white, then coat the whole thing with a gloss.
"Imagination is the dye that colors our lives"
Marcus Aurellius
A good friend will come and bail you out of jail...but, a true friend will be sitting next to you saying, "Damn...that was fun!"
