If you've got honey comb, you've got bee's wax. It's just a matter of seperating it.
I'm assuming it's less than a pound. If it's more than a pound, break it into one pound chunks and do them seperately..
The easiest way to seperate the wax from the honey is in a clear glass container. ( A clear drinking glass designed for hot liquids would be good.)
Place the honey comb in the glass and gently heat it. DON'T boil it !! Once the wax melts it will seperate from the honey, and form a seperate layer. Once it's all seperated, shove it in the fridge for a hour or so, to let it set up.
Once it's set, nice and hard, take it out and use a table knife to lossen it from the sides of the glass. Lift it out and rinse it with Cool water. Cool water will remove any honey, without softening the wax.
You'll now have a chunk of bee's wax, suitable for your rigging.
Take it slow and carefully, and good luck.
Mike K.
