I am working on my second 1/700 Victory ship, and trying to do a more accurate job that the first attempt. Having actually seen, touched and crawled over, under and through one last month certainly helped!
I need to add a little bit of bulkhead on the boat deck, where there is a gap between the superstructure and the forward kingposts. My question is, can I get away with using some of the thin resin overpour, since it is flexible and there's a curve involved instead of a right angle? Or will it be too fragile?
I would rather do that than spring for MORE styrene - I've already invested in the .-25-inch styrene rods for the cargo booms because they have got to be easier to work with than brass, but would rather not buy more stuff I won't use up in 10 years.
