need help from some of you pro ship builders out there
Posted by Anonymous on Tuesday, June 14, 2005 6:18 PM
greetings. i have been searching for a u.s.s. arizona in 1/350 scale. i have found the names of a few manufacturers of this ship in this scale but ran into a mystery. the manufactuers that i have found are
1. Banner
2. Trumpeter
3. Dragon { ? }
every time i try to bring up the one made by trumpeter, what comes up instead is one made by "MiniHobbyModels". from the outside of the box it appears to be a cheap knock off but i have heard that this kit was leased or sold from trumpeter to minihobbymodels. is this true ? and if so, was the kit changed in anyway ?
also, to anyone who speacializes in building 1/350 scale ships - could you please let me know a good tool list and techniques for building in this scale. one more thing - what are some of the pitfalls of this scale or shipkits in particular that you've encountered and how did you overcome them.
thanks to all who can provide assistance in the above areas
    March 2004
Posted by MBT70 on Tuesday, June 14, 2005 6:43 PM
For starters, there is a very good set of etched brass details available from Gold Medal Models that can be ordered through Pacific Front Hobbies in Roseburg, OR. at http://www.pacificfront.com.
Life is tough. Then you die.
Posted by Anonymous on Tuesday, June 14, 2005 8:58 PM
The MiniHobiesModels/Trumpeter/Banner kit is all the same one. And it's the only injection modeled kit in 1/350, the others are resin and very expensive. The kit it self is actually a good starting point, I say that because it wasn't designed all that well as a kit. The 01 deck (boat deck) and all the superstructure decks are put together in a "sandwhich" fasion which leaves a seam horizontally in the middle of the deck. With the addition of photo etch and some scratchbuilding it can be built up into a pretty accurate model of the Arizona.
Posted by Anonymous on Thursday, June 16, 2005 3:52 AM
appreciate the feedback folks. anyone else want to throw a few more answers out there ? i would definately appreciate it.
Posted by Anonymous on Friday, June 24, 2005 3:35 PM
only 2 members are willing to offer advice ? come on now, i heard that this was a friendly board with lots o people willing to offer advice
    January 2003
Posted by Jeff Herne on Friday, June 24, 2005 4:16 PM
We are friendly, it's just that it's Friday and some of us are still working!! Big Smile [:D]
To answer your question, the Banner/Trumpeter/Minihobby kit is the same across the board, as Abram mentioned. You have several choices with regards to PE, but Gold Medal Models and White Ensign are your best bets.
You can replace the open 5"/25 mounts with resin update parts from L'Arsenal, and you can paint your model with the proper colors (enamels) from White Ensign's Colorcoat line. You'll need 5-L Light Gray and 5-D Dark Gray, and Hull Red. Decks were natural teak. Paint the vertical surfaces 5-D Dark Gray up to the funnel tops, everything above that is 5-L. Kingfishers were generally flown off to Ford Island, I don't recall, but I think Arizona didn't have hers onboard at the time of the attack.
When you build the deck structure, pay extra attention to the seams, the deckhouses are split in half and will have a nasty seam running through the middle of the portholes. Lionroar has released a set of templates that overlay these parts to eliminate this problem. I know they exist, but have never heard any feedback from anyone who's used them. You can update your midship section with Tom's Modelworks boat set, it provides photoetched cradles for the stacked boats.
Anything else?
Jeff
