turret blast bags
turret blast bags
Posted by pingtang on Thursday, July 3, 2003 7:51 AM
Hi all
I am currently building a 1/350 scale Bismarck and was wondering if anyone had any tips for making blast bags for the 38 cm main turrets and the 15 cm secondary turrets.
Any help would be much appreciated.
-Daniel
    January 2003
Posted by therriman on Thursday, July 3, 2003 9:35 AM
Use aluminium foil as a backing, and fill in with white glue (applied with a pin usually, and letting set up as you go) until you you have the desired shape. Then paint black and dry brush for weathering. Make sure that they look as much alike as possible.
Tim H. "If your alone and you meet a Zero, run like hell. Your outnumbered" Capt Joe Foss, Guadalcanal 1942 Real Trucks have 18 wheels. Anything less is just a Toy! I am in shape. Hey, Round is a shape! Reality is a concept not yet proven.
    January 2003
Posted by Jeff Herne on Friday, July 4, 2003 12:50 AM
I use tissue paper soaked in a water/white glue mixture...
Jeff Herne
Modelwarships.com
    January 2003
Posted by therriman on Friday, July 4, 2003 7:48 PM
Jeff,
I hadn't thought of that. I'll have to remember that. What ratio of mixture? 50/50?
Posted by Anonymous on Monday, July 7, 2003 10:39 AM
i use elmers white glue & shape it into blast bags around each barrel then paint the required color
