Deck caulking
Deck caulking
Posted by Anonymous on Monday, August 29, 2005 5:14 PM
Hi Folks, On sailing ships, was caulking applied to lower deck planking as well as top deck? Were all decks caulked? I plan to do scene with a 32 pounder gun plus gear. As far as I can tell they were only used on lower decks because of their great weight. Thanks in advance, John.
    May 2003
Posted by jtilley on Monday, August 29, 2005 11:09 PM
The simple answer is - yes. Keeping water from getting through planking was essential in every part of the ship.
During the period you're talking about (the late eighteenth or early nineteenth century, I assume) the caulking probably would take the form of tarred oakum - a dark grey in color. The edges of each plank would be planed off at a slight angle, to create a groove for the caulking. The strip of caulking usually would be between half an inch and an inch wide. The caulking would show up on each side of each plank - including the ends.
In high-quality work (which usually characterized large British warships) the deck planks would be fastened to the beams with either wood treenails or metal bolts (depending on the period). In either case, the shipwright responsible for that part of the job would start by boring a hole (actually usually two holes, side by side) halfway through each plank wherever it crossed a beam. The hole would be about an inch and a half in diameter. He would then switch to a smaller bit, (the same diameter of the fastening), center it in the hole, and drill the rest of the way through the plank and into the beam. Then he would pound the fasting through the plank and into the beam, leaving the head of the fastening countersunk below the surface. Next he stuffed some hot caulking into the hole and pounded in a wood plug, which was cut from the face grain of a board like the deck plank. When the caulking was dry the protruding part of the plug would be planed off flush.
The purpose of this ritual was to make the grain of the planks and the plugs identical, so that when the deck was scraped or holystoned the plugs and the planks would wear down at the same rate. For model building purposes, the point of all this is that the fastenings would show up in the form of hollow, dark grey circles - not the black spots one sometimes sees on models.
Whether all this is practical to reproduce on a model really depends on the scale. On small scales, a good, simple way to represent caulking is simply to run a fairly soft pencil around the edges of each plank. The pencil line will survive any sanding or scraping inflicted on the deck, and, to my eye at least, the color is just about right.
Hope this helps a little. Good luck.
Posted by Anonymous on Tuesday, August 30, 2005 2:58 AM
Thanks J, I've seen oakum used on local trawlers, but only between the planks on the ships side. The deck planks were poured with melted pitch, I assumed it was always done this way, but I suppose everything developes from previous practice. I had intended to use black water paint mixed with "plastic wood" as caulking. I used this before on a WW2 trawler and it looks ok. Thanks for your help and expertise, John.
