rigging material
    September 2004
rigging material
Posted by flaver on Friday, September 2, 2005 5:42 AM
I am building the ICM 1:350 German Konig class ship,
Though I am not at this stage yet I am wondering what I should use for rigging?
Fine thread or stretched sprue?
Any suggestions?
Thanks in advance.
    May 2005
Posted by Ron Smith on Friday, September 2, 2005 9:57 AM
If I want it taut and it's a long run or needs to be flexible during istallation I use fly fishing tippet and tension it with heat. If it needs to be taut and it's a short run and it doesn't need to flex much to install I use stainless steel catheter lead (.005" dia. painted to what ever color). For sagging lines I use either the catheter lead or the fine EZ-Line (Berkshire Junction, check model railroad places).
For stuff smaller than 1/350 I usually use smoke colored invisible thread and leave it unpainted.
    September 2004
Posted by flaver on Wednesday, September 7, 2005 6:16 AM
Thanks, I think this is going to be quite challengeing, the mast for the rigging is quite thin, I am not quite sure how I am going to pull this off with out it bending to hell. I think the rigging will have to support it's self, but we shall see
    January 2003
Posted by Jeff Herne on Wednesday, September 7, 2005 3:55 PM
I usually replace the masts and yards with soldered brass for that very reason. I typically use .004 quilting thread for just about everything.
Jeff
    September 2004
Posted by flaver on Tuesday, September 13, 2005 5:38 AM
I had the same thought about the masts, and I did so this week. Since I'm not a ship modeler normally, besides u-boats, this has proven to be quite a tricky project. But all the rigging masts have been cut off and replaced with brass.
