ref how do i
ref how do i
Posted by Anonymous on Friday, September 9, 2005 2:50 PM
i have finished my 1:72 revell u boat and am getting ready to weather and place decals but as this is my third model i have built i have a few Q's 1. i have read that you have to seal the model i was wondering do you seal the paint before weathering and placing decals?? 2. i want to display the model but do not have the skills to make a diorama but wish to show the model firing a torpedo and am wondering how i would go about making a torpedo, the scale, and how to make the wake the torpedo makes when it leaves the boat?? 3. and to post the pictures on this forum.
    August 2005
Posted by EdGrune on Friday, September 9, 2005 4:49 PM
1) Decals stick better to a glossy painted surface than to a flat painted surface. If you have used a flat paint, you may want to use a glear gloss. Use a paint which is compatible with plastic and the brand of paint you painted the model with. Future acrylic floor polish is also commonly used. You can brush a thin coat in the area where the decals will go. When the gloss paint or Future is dry you can apply the decals.
You can seal the decals down now with some clear flat paint - or if you intend to weather the model, use a clear gloss like you did with the decals. The gloss will allow you to remove mistakes easier than from a flat paint. If you painted the model with enamel paints, use water-based acrylic paints to apply your weathering (or vice versa). Apply a wash to weather a little at a time. It is easy to add more. If you make a mistake you can wipe it off. The gloss-sealer helps you do that.
When you are happy - an overall sealer coat (flat?) will seal in your weathering and allow you to handle the model without the weathering coming off on your hands.
2) Here are a couple of articles on making water for dioramas
http://www.steelnavy.com/water.htm
http://www.steelnavy.com/Whitewater.htm
http://www.steelnavy.com/WavePatterns.htm
How do you want to model the torpedo? Do you want it just coming out of the tube? Do you want it just entering the water, or running along in the water? If its just coming out of the tube or just splashing in - you may not need to model the whole torpedo. Use a piece of wooden dowel of the appropriate diameter and sand the nose or tail shape. Make fins out of cardboard or plastic sheet. You can purchase resin torpedos from companies like White Ensign Models.
If you want to do your torpedo running after it has splashed in you can still use a wooden dowel. You may be able to do it with some cardboard - since the torpedo will be imbedded in the water. Part of the fun is engineering a solution that works for you.
Remember you are modeling for yourself. You do not have to make anybody but your harshest critic - yourself - happy. Do the best you can. Make yourself happy in your modeling efforts.
3) I posted the link to how to post photos in an earlier response
Posted by Anonymous on Friday, September 9, 2005 5:45 PM
thank you edgrune like i said i think i will need to practice with the water but i want the torpedo alreafy left the sub and enroute to the target so i will need to replicate the swirl and wake of the water and try to figure out how to atach the torpedo and the scale and exactly what a german torpedo looks like.
thank you again edgrune
    April 2005
Posted by Imperator-Rex on Saturday, September 10, 2005 5:41 AM
For the torpedo, you can check out White Ensign Model: they sell two for about £4.00.
Review (loading set and torpedoes): http://www.steelnavy.com/WEM72LoadingSet.htm
