Putting rivets on a ships hull
Posted by Anonymous on Tuesday, September 20, 2005 7:10 AM
Hi there,
First time member and user of this forum. I have purchased a 1/72 scale Revell warship kit and although quite detailed the makers seemed to have neglected the finer details such as rivets on the hull and the superstructure.
I have thought of a variety of means to dot the hull (and other appropriate areas) with well-placed rivetting but I would rather ask the experts if there is a way of achieving this end. I thought of dipping a toothpick in paint but I can see this will take an eternity and end up putting me off the model.
Not sure if I should just bite the bullet and give the rivetting a miss but the scale does allow to show rivets and my Virgo perfectionism drives me forward.
Thanks in advance for any tips or help.
Ken
    January 2003
Posted by devinj on Tuesday, September 20, 2005 8:43 AM
There's no real quick and easy way I know around placing rivets. Well, maybe two: decal strips with little dots printed on them, or using a ponce wheel to make indented rivets.
One thing I've done in the past on sci-fi subjects that need this detail is to drill small holes along a line, and then cut off pin heads and glue them into the holes. You'd probably go blind doing that on a 1/72 kit, though.
-Devin
    December 2003
Posted by scottrc on Tuesday, September 20, 2005 8:47 AM
Toothpicks work kinda ok, and so do fine brushes. My technique is to use a straitedge, pencil and a syringe filled with medium CA.
Draw a line and make marks as to where the rivets are to go and then place rivets by using the syringe and CA. I have also tried 30 minute epoxy for a more robust rivet, but it doesn't go through the syringe as well.
You may think it may take and eternity, but it really goes pretty fast.
Scott
