Fletcher class update
    June 2003
Posted by radartec on Tuesday, October 18, 2005 12:37 PM
Looking to update 1/350 Fletcher class 2100 tin can to mid 60's.Does anyone make SPS6 radar in PE?How about the tripod mast? The triple torpedo tubes?60's ECM antennas?I do have the square bridge conversion kit already as I am building the USS INGERSOLL DD652.Any help is greatly appreciated.
    January 2003
Posted by Jeff Herne on Tuesday, October 18, 2005 1:17 PM
Gold Medal's modern USN set lists the following: railing in several styles including pre-shaped sections for upswept bow. Vertical and inclined ladders, flight deck safety nets, SH-60 helicopter rotors, yardarm footrails and anemometers, screws for Spruance and Ticonderoga-class ships (1/350 version only), SPS-6, SPS-10, SPS-12, SPS-29, SPS-40, SPS-49, and OPS-14B radars, masts and platforms for FF-1052 and FFG-7 class ships.
As for Mk13 torpedo tubes, ASROC, and tripod masts, you'll either have to scrounge them from another kit, scratchbuild them, or contact Commander's models and ask if they'll sell you parts from their FRAM Gearing kit.
Jeff
    August 2005
Posted by EdGrune on Tuesday, October 18, 2005 2:30 PM
Veteran Models sells accessory packs in 1:350 scale
A vendor in the States is Commanders/Iron Shipwright. See the link on their page at
http://www.commanderseries.com/veteran_models.html
Veteran includes the triple torpedo tubes and the ASROC launcher. They are very high quality.
You can probably make the tripod mast better out of brass rod or tube. Resin masts are usually soft and warp or break or warp under the strain of rigging.
Tom's Modelworks makes a square-bridge update set for the Fletcher. It is not in the online catalog and I believe it is going out of production. I've heard that Tom Harrison of Tom's has several sets left. Contact him directly regarding availability
    June 2003
Posted by radartec on Friday, October 21, 2005 10:34 AM
Thanks for the leads.I need help in locating The Floating Drydock book-"The Fletcher Class Destroyer Plan Book".It is out of print and neither The Floating Drydock or Pacific Front Hobbies can help !!!
    January 2003
Posted by Jeff Herne on Friday, October 21, 2005 11:07 AM
Good luck finding a copy...I got mine (after a long search) from Bob Steinbrunn, he had just finished his USS Kidd model a few years back.
I would suggest posting to the message board at Steelnavy and Modelwarships.
Jeff
    August 2005
Posted by sumpter250 on Friday, October 21, 2005 1:08 PM
you may want to check this site out for photos, and info.
http://www.destroyersonline.com/usndd/classflet.html
Pete
Lead me not into temptation ..................I can find it myself
    June 2003
Posted by radartec on Friday, February 26, 2010 7:51 PM
I finally did buy the GMM set to get the SPS6 radar antenna and did scratch build the tripod mast.I only work on it in the winter so it is slow going.Took 5 days to scratch build the mast and antennas and will still need more work
