U-253 in Progress Continues...
Posted by Anonymous on Thursday, December 1, 2005 6:56 PM
I finally got around to taking some pics of the very slow progress of my U-253. I got the hull together with the upper pressure hull kit and pieced the brass deck togther. I plan on using the metal deck pieces from Eduard on the bow and stern sections. I also plan on using the Eduard kit for the other details on the deck. You'll see that I sanded the areas on the deck where I had the Modelbrass details. I found them too thick and not accurately detailed unlike the Eduard.
The upper pressure hull is nice. But I found the mid section to be a little sway back and the pieces didn't quite match up with each other. Not that it matters since they'll be covered up anyway. It does give the boat a nice weight. I did add the conning tower to it and the housing for the sky 'scope, plus the ammunitions container. I didn't add the missing aft torpedo loading hatch. I think it may have not been there in the first place because you couldn't see it if it was there.
The brass deck is great. The attention to detail is superb. This is the only deck with the correct scale flood slots out there. It's a little bit of a pain to shimmy it and piece it together, but it's well worth it.
http://homepage.mac.com/jess13/PhotoAlbum62.html
Take Care,
Jess
Posted by Anonymous on Saturday, December 3, 2005 8:47 PM
You will have a blast doing this kit. I have built 4, but have been out of the box. I didn't see the need to add the PE sets since Revell has gone way out on this kit. I drilled out all the flood holes, which makes a big difference. You can also throw in a crew from Andrea or CMK to add life to your build. The proper weathing is important, which will show the toll the elements make on the U-Boat's skin after a 3-4 month cruise. I did not use the kit's black thread for the jump wires beause they are fuzzy. I used a very fine plastic thread which resembles the proper scale for the wires.
Posted by Anonymous on Sunday, December 4, 2005 12:28 AM
This is actually my third with a fourth and fith coming soon.
I love the PE sets, especially the Eduard.
You should post some pics of your builds.
Jess
Posted by Anonymous on Sunday, December 4, 2005 7:28 AM
I will do so next time before they are sold. I'm working on another one which I may keep this time. Those little CMK guys are very hard to work on but add character to the boat.
