Jeremiah O'Brien
Jeremiah O'Brien
Posted by modeler bill on Monday, December 5, 2005 11:44 PM
I'm building the above kit, taking a break from WW11 aircraft, and it has millions of tiny parts! Since 99% of the parts are the same color, what do you modelers do? Paint the parts on the sprue as best as possible-OR- remove them in "groups" and paint. Even painting them on the sprue, you will still need to paint where you removed them and also the mold parting lines will need to be scratched away and then painted again. Give me your BEST way ? Thanks, Bill
Posted by Anonymous on Monday, December 5, 2005 11:48 PM
I think you've answered your own Q,lol
There is so much cleaning up of parts, that I find it better to remove/prep/ then paint in batches of colour. I'm doing the 1/100th heller victory that has over 2100 parts so I feel your painSmile [:)]
No short cuts, no easy way I'm afraid, get stuck in and enjoy it, the sprues soon start to dissapear.
    March 2005
Posted by mfsob on Tuesday, December 6, 2005 9:46 AM
I think it depends on the scale. That's a 1/350 kit, right? So at least you can see most of the parts. With the 1/700 ships I build, I tend to keep the smaller parts on the sprues, clean up as best I can, paint and then remove them one at a time for final cleanup and gluing. And with ships, large groups of parts will be all one color, so I do try to get all the ones that will be haze gray, for instance, cleaned up so I can spray paint them all at once.
With the 1/72 airplane I'm currently building, though, I found it a lot easier to cut off all the parts, clean off the flash and paint them in groups of like colors. Only a few tiny bits were painted on the sprues.
    December 2005
Posted by onyxman on Wednesday, December 7, 2005 10:05 AM
The O'Brian is easy to paint because it's just about all one color. The only major parts that aren't grey are the hatch covers and the lower hull if you are doing a full hull model. The dark grey decks shown on the instructions are bogus. When I did mine I chose Model Masters light Gull Grey paint which so closely matches the color of the plastic, if you miss a few tiny spots with the paint nobody can tell. So, for the most part I didn't paint most small parts until they were in place on the model and then I sprayed the whole thing. Some sub assemblies can be sprayed separately, like the mast houses, stack etc. The hatch covers ( green tarp ) can be brushed separately and put on at the end.
Posted by modeler bill on Wednesday, December 7, 2005 8:08 PM
Onyxman: I didn't realize there where green tarps on the ship nor does the plans call that out, butt I think you have an idea. If I painted the tarps green it would at least give it some color!
I have sent for the CD from Tom's Modelworks so I might add PE parts to the kit, but if you (or anyone else) have ideas I could add please let me know. WW11 ships I haven't completed before. Cheers, Bill
MJH
    April 2005
Posted by MJH on Thursday, December 8, 2005 4:37 AM
I have a more extreme view of the painting of a Liberty ship.  Assemble it completely (as a waterline model), and then spray the whole thing light matt grey.  Pick out a few details such as the tarps mentioned and follow this with lots of rust-coloured washes and other dirtying-down methods.  Finally I'm going to fit it out with all the vehicles and aircraft from Tom's.
If you have a look a this site  http://www.armed-guard.com/calen3.html  especially the second and second to last photos you can see it's pretty well wide open.  The Trumpeter painting instructions have no basis in fact that I have been able to establish.  Even the black boot-topping is wrong.
Michael
    December 2005
Posted by onyxman on Thursday, December 8, 2005 11:14 AM
There is an extensive thread here from last summer with good info on the inacuracies of the Trumpter kit and instructions. To be accurate in wartime configuration they only had anti fouling paint to the 10 ft draft mark (up from the keel) and no black boot topping at all. MJH's idea of doing the waterline version will save probably half the labor on the kit. I did mine full hull and spent a lot of time sanding and filling the seam. I also used the Tom's deck cargo. With the whole ship being grey, a full load of deck cargo adds  color and complexity. Here are some more vintage pics. Note the flagstaff forward of the aft house, and the small mast forward of the stack on the port side. The last pic shows a lightly laden ship and you can't see any boot topping.
http://www.armed-guard.com/lsip613.jpg
http://www.armed-guard.com/lsip790.jpg
http://www.armed-guard.com/la040c.jpg
http://www.armed-guard.com/lsip472.jpg
and here is mine
    March 2005
Posted by mfsob on Thursday, December 8, 2005 8:28 PM
onxyman is correct, Chris Freidenbach (sp?) a crewman on the real Jeremiah O'Brien, gave an exhaustive rundown earlier this year of all the little things you have to do to make a truly accurate model. You MIGHT be able to find it by doing a search.
When I was building my 1/700 resin Victory ship I had another consultant, my Dad, who served on several during the war. He said that while the ships were usually a gull or haze gray shade, the decks were sometimes a darker gray, like modern US Navy ships, but sometimes the entire ship was the same color - it just depended how much paint and what colors they had on hand when they started painting. And you know how they paint a deck in the merchant marine? Easy! Get a 5-gallon can of paint, kick it over, and go at it like dervishes before any runs into the scuppers and down the sides of the hull!
As for the canvas hatch covers, they do provide some color. Dad remembered them as being a rusty or dirty brown, but I opted for a newer look by using a green, based on what Christ Freidenbach said. I went through a ton of greens at the hobby shop, and finally settled on Model Master RAF Interior Green, #2062, as looking the most like newer canvas circa WWII.
 There are other "spots" of color - the firehoses will be off-white with a brass nozzle on the end, and a flat red curved holder; fire hydrants were commonly red; life rings could be either white or gray, depending on who was doing the painting that day; the ship's name board would be flat black with white block lettering; the various running and navigation lights would provide points of red, green and white; deck cargo crates can be many different shades of tan and brown; you get the idea. When I modeled the LaCrosse Victory that my Dad served on, I included a deck cargo of Sherman tanks that he remembered from one trip, along with cargo crates and oil drums in various shades of black and green. Add a few crewmen in their dark blue dungarees, blue workshirts and white hats, and it's more than enough to break up the mass of gray ship.
Posted by modeler bill on Friday, December 9, 2005 12:44 PM
mfsob: Thanks for your input. I wwil make a concerted effort to add the features you have mentioned. Cheers, Bill
    March 2005
Posted by mfsob on Saturday, December 10, 2005 8:27 AM
Just remember, Bill, it's YOUR model. The only person you have to please is yourself ... and sometimes I think we are harder on ourselves than any reasonable observer would EVER be!
    April 2005
Posted by ddp59 on Saturday, December 10, 2005 12:19 PM
because we know better & most others don't.
Posted by modeler bill on Saturday, December 10, 2005 3:44 PM
mfsob: Where could I purchase "deck cargo" and oil drums in 1/700 scale? Thanks, Cheers, Bill
    August 2005
Posted by EdGrune on Saturday, December 10, 2005 4:07 PM
1:700 scale vehicles are available from Loose Cannon
or you might try the old PitRoad green box set of Vehicles on  the Beachead for some Shermans, Dodge command cars and duece and a halfs
Aircraft deck cargo are also available from some of the PitRoad aircraft sets
Make sure you get the cribbing right.
As far as oil drums - are you sure you want to do them?   IIRC a 55 gallon drum is between 18 and 24 inches in diameter.   In 1:700 scale that works out to be about 0.025 to 0.035 inches.  Get yourself some Evergreen rod and a Chopper and make as many as you want
    March 2005
Posted by mfsob on Saturday, December 10, 2005 7:49 PM
bill - I got the resin deck cargo, which included oil drums on pallets, boxes of various sizes on pallets, and loads of pipe, from Loose Cannon Productions, same place I got my excellent Victory ship model. Drop Dave a line at the link below, I think it was $10, more than enough to cover most of the hatches!
http://home.earthlink.net/~loosecannonproductions/David.html
The vehicles I used came from White Ensign Models in England. Another fine company.
    August 2005
Posted by EdGrune on Sunday, December 11, 2005 7:45 AM
Don't contact Dave Angelo.  He has been deployed and will be gone for most of a year.  Contact his business partner Hugh Letterly
http://home.earthlink.net/~loosecannonproductions/Hugh.html
    March 2005
Posted by mfsob on Sunday, December 11, 2005 8:54 AM
You're kidding! I just talked with him via e-mail about a week ago. Hope he stays safe wherever he ends up.
    August 2005
Posted by EdGrune on Sunday, December 11, 2005 8:57 AM
He posted on SteelNavy that he was being deployed and that he was wrapping up his end of the business - and letting Hugh run it until he returned
