wdolson2 wrote: |
If you want to go cheap. Albatross made a 1/700 injection molded Gearing. I'm not sure, but Skywave may have released one too. The Albatross kit is the pre-FRAM version.
I disagree with your going cheap assesment. I went to the Pacific Front online catalog and totaled what I feel is necessary to kitbash a FRAM Gearing using currently available kits & parts. This is based on what I did to FRAM a Gearing a dozen years ago.
Skywave Gearing (W32) 14.00 USD (basic donor for hull, superstructure & guns)
Skywave Callaghan (W01) 10.00 USD (donor of enclosed bridge & tripod mast)
Skywave USN/NATO weapons (SW32) 6.00 USD (MK32 torpedo tubes & ASROC box launcher)
Gold Medal Models USN Ship PE 12.00 USD (Radars - to be equivalent to the JAG kit)
Evergreen rod & sheet stock 7.50+ (build replacement structures & ECM mast)
Decals ---- (you will have to scrounge)
Research Material -----
Total 49.50+ USD
On the otherhand the JAG Collective 1:700 scale FRAM Gearing is 32.00 USD - includes everything necessary plus decals. You supply the glue & paint.
If you want to go cheap - go with the JAG. Its 17+ USD cheaper (and the quality is miles ahead)
One of the common misperceptions is that resin kits are more expensive than styrene. Qualtiy resin kits supply all the parts you need to complete the model. You do not need to go purchase aftermarket details. And JAG has done the heavy lifting for you as far as research.
Albatross has been out of business for about 10 years. They were a one-hit wonder with their Gearing/Sumner kit. Quality-wise they were behind the Japanese waterline consortium of the day. The shape of the bow is totally wrong & must be reworked. The bulkhead details are missing. Comparing their quality with that of the current styrene kits comong out of China - they are light years behind.
edited by efg
Oops, forgot about the stack caps. When I did my FRAM Gearing years ago there were no stack caps available. I scratchbuilt one and made resin castings so that they were exact duplicates. Nowadays you can get some stack caps off the DML Adams/Cochrane kit. Add another 10 bucks for that kit or more if you decide to go with the resin casting route.
