Butterboard
Butterboard
Posted by Anonymous on Monday, December 19, 2005 11:38 AM
Has anyone tried using "Butterboard" for making hulls for scratchbuilt ships? I've been using .080" sheet for the maindeck, with a .16" laminated keel and frames of .040" sheet....then filling the voids with polyurethane resin. Read somewhere about this "Butterboard", and was wondering if it would be worth the expense - the stuff is fabulously expensive. Anyone have any experience with it?
    December 2003
Posted by scottrc on Monday, December 19, 2005 2:17 PM
Bread and Butter method.  Where you take a sheet of either wood, metal, or plastic, or whatever and spead it with an adhesive, and apply another sheet over it, clamp it together and repeat until the desired thinkness.  Also called laminating in the non-ship modeling world.
I met modeler's who also called it also the Bread-board method because the laminates are pinned to the board while being cured and shaped.  You can form a skeleton from laminates and fill the voids with epoxy or resins.  The method still is the same.
I have been using this method in building 1/700 hulls and modifications since it is easier to build up the contours and shape the hull than trying to shape a hull from a solid piece of material.  For my current post war Essex modification project, I have been combining a layer of styrene, followed by a layer of polyburate epoxy resin, followed by a sheet of basewood to form a stong, yet easily sandable composite.
This type of construction is a very old form of ship modeling and is worth learning.
Scott
    May 2003
Posted by jtilley on Monday, December 19, 2005 2:22 PM
I've heard of a product called "Butterboard," but I've never seen it.  I have a vague recollection of having read an article by somebody who'd used it for ship modeling in some context, but I can't remember where.  Seems like it may have been in FSM.  I'll keep trolling through my Halfzeimer's-afflicted memory.
Posted by Lufbery on Monday, December 19, 2005 2:44 PM
This product was mentioned in Ships in Scale recently.
I've never tried it, but it sounds neat.
Regards,
-Drew
Build what you like; like what you build.
