wooden Masts and yards
Posted by Anonymous on Tuesday, January 10, 2006 7:48 PM
Go day to all of you,
I have been convinced and wil proceed with making wooden masts and yards for my Santa Maria. As for most of us, $$$ is an issue. I will therefore need to work the round dowels by hand using a shaver, razor blade and sandpaper. As thoughts of the future keep cropping up, I am wondering about buying a lathe for this purpose. Do you feel a hobby lathe will be long enough? Here in Taiwan, I can get Proxxon. They have a hobby lathe that has a center distance of almost 10". Would this be long enough for my needs? As a caveat, I gues the largest ships I will do will be 1:96 Hellers and possibly some actual wood ships. I am just not sure on wht length some of masts or yards will be when I get to this point. The Proxxon lathe model # DB250 costs about $150. For a professional on the price goes up substatially. Are there possible alternatives?
On the side, my Pamir is being repainted. Someone messed up (It wasn't me!Wink [;)]). And paint does not fix a problem. I am using my best friend Oven cleaner. It is still taking some effort on the toothbrush side to get the paint off. Even harder in the bulwarks due to the verticle ribbing. I just could live with the way it was looking.
Cheers,
Robert
Posted by Anonymous on Tuesday, January 10, 2006 9:37 PM
you can remove the tail stock and use a floating center, then you can put (within reason) any length of material you like in there.
Posted by Anonymous on Wednesday, January 11, 2006 1:08 AM
Thank you Vapo for the idea.
I ahve gone to the Proxxon website and looked over the lathe. The tailstock can be removed but I donot see anything about a floating center. I ahve never really worked with these before so foregive my inexperience. (What is meant by floating center?)
to change subject abit, how is the baby daughter? Is she doing well at not letting you sleep?
Thanks again,
Roert
Posted by Anonymous on Wednesday, January 11, 2006 2:39 AM
hence my reply at 3.30amZzz [zzz]
Maybe they don't make one, but you can! it's simply a post that attachs to the bed(does not have to slide in this instance). it has a hole that lines up with the chuck(3 jaw).
your material will be held in the jaws, while the other end goes through the hole in the post.
They would normally be adjustable so as to take up the gap, but in this case, make the hole slightly bigger than the material and run the lathe slow!!! it will take longer to turn down, but at least you can work on longer material.
I'll have a look over their web site maybe they call it something else.
Posted by Anonymous on Wednesday, January 11, 2006 2:43 AM
ok, for some reason their website won't work on my pc very well. but looking at that lathe, the tail stock winder should drop out, leaving the tailstock, I would be very supprised if they don't offer some form of center for it, it may be included in the thing, failing that, it would be very,very easy to make one.
    August 2005
Posted by EdGrune on Wednesday, January 11, 2006 7:49 AM
See the Nautical Research Guild Shop Note on construction of a mast & yard lathe using a Dremel tool
http://www.naut-res-guild.org/minilathe2.htm
While NRG members certainly will use top end minilathes to turn parts for their ship models,  they also use tools readily at hand to perform more mundane tasks such as sanding a taper into a dowel
Posted by Anonymous on Wednesday, January 11, 2006 8:27 AM
Well Vaso and Ed, thank you.
I like the dremel idea by Ed. Now I only need to buy the Dremel and make a lathe. That is more money for my models.
I have seen other items which connect to a Dremel which lets you use it as a drill press, router, etc. Now that is a fine tool.
Do you think with all of these abilities, it can keep the wife from gabbing. (SLAP)
Thanks again,
Robert
    May 2003
Posted by jtilley on Wednesday, January 11, 2006 8:42 AM
I don't own any Proxxon tools, but I have the impression that they're quality merchandise.  (I do have a MicroMark variable-speed table saw, which I think is identical to the one sold under the Proxxon label.  I'm completely satisfied with it.)  I suspect that Proxxon wood lathe would do the job more than adequately.
The problem is that a lathe like that won't do a lot more for a ship modeler than taper and smooth dowels. For a little (well, more than a little) more money you can get a lathe with a crossfeed, which can also turn metal, plastic, and virtually anything else.  My lathe is a Unimat SL, which I bought in 1975.  (Still going strong, though it's had its motor replaced once.)  It has a hollow headstock.  On those rare occasions when I need to turn a particularly long spar, I generally start by feeding the dowel through the headstock from the back end and turn half of it.  Then I turn the dowel around, feed the other end through, and turn the rest.  When it comes time for the final smoothing-out, I remove the tailstock, chuck the fat end of the dowel into the headstock, and hold the other end in my right hand while the left hand holds the sandpaper.  It's a little awkward, but it works fine.
This is probably none of my business, but I can't help wondering whether, at this point, a lathe really is the best power tool for you to be spending you money on.  If you're just thinking in terms of tapering spars, you can get perfectly good results with an electric drill.  Clamp it down to your workbench, chuck the dowel in it, and hold the other end of the dowel in your free hand (preferably with the help of a soft rag, unless you enjoy the smell of burning flesh).  At least one company makes a drill attachment that works about like the gadget in Ed Grune's photo.  You can clamp the accessory "tailstock" on the edge of a bench or table at any distance from the drill you like.
Do you already have a Dremel Moto-Tool or something similar?  If not, I think most experienced ship modelers would agree with me:  that's the first power tool to buy.  You can do all sorts of things with it, from drilling holes to cutting slots to polishing metal to sharpening tools to routing decorative edges around baseboards.  Just be sure to get a variable-speed version - or, even better, a single-speed tool with an accessory speed control that goes down to (or near) 0 rpm.  (The slowest speed on most Dremel variable-speed models is 5000 rpm.  A drill bit running at that speed will melt plastic and burn wood unless it's extremely sharp.)  The truth is that, for at least 90 percent of the jobs involved in plastic ship modeling, the smallest battery-operated Dremel tool will be more than satisfactory.  It costs less than $50.00.
My current favorite "motor tool" is a little gadget marketed by a German company called We-Cheer.  (I think it's made in Taiwan; you might be able to find the same tool under a different label.)  It's about seven inches long, light as a feather, and uses Dremel chucks.  I keep it plugged into my ancient Dremel "Tabletop Speed Control," but any other speed control designed for power tools surely would work.  I bought the thing at Woodcraft for $25.00.  Here's a link:  http://www.woodcraft.com/family.aspx?FamilyID=3736
All this is, of course, a matter of entirely personal opinion.  You're the best judge of what tools are most appropriate for your purposes.  Good luck.
    December 2003
Posted by scottrc on Wednesday, January 11, 2006 10:18 AM
I would comment on what JTilley just just mentioned.  If your going to do a few tapers on spars and other simple scratch build projects, then the dremel lathe will work.  I have a small wood lathe and never use it.  I also have a Unimate multi-axis mill that has paid for itself many times over.  It cost me $400.00, and they now sell for around $900.00.  But for a tool that will shape, cut, hone, taper, and drill many different types of materials different axis, you can't beat it.
Scott
    May 2003
Posted by jtilley on Wednesday, January 11, 2006 11:47 AM
Bear in mind one built-in limitation to any gadget involving a Dremel tool.  Unless you install some sort of aftermarket chuck on it, it has a maximum capacity of 1/8".  That's big enough for the spars on lots of small-scale models, but not enough, for example, for the lower masts of a frigate or ship-of-the-line on 1/96 scale.
Don't laugh too loud at the idea of using a plain, old-fashioned electric drill.  People have been using drills to produce perfectly good spars for decades.  Remember that, for this sort of work, a wood lathe only does one thing that a drill doesn't:  the lathe holds onto both ends of the dowel.  There are, as we've noted already, various ways to deal with that problem.
    August 2005
Posted by EdGrune on Wednesday, January 11, 2006 12:07 PM
DocTilley, I agree with what you are saying regarding the electric drill.  I have done that.  But,  I would invite you to go back and reread Morgenstern's article which I linked from the Nautical Research Guild.
In it he describes his method of creating both live and dead centers for use with his Dremel-powered home made lathe.   The diameter of the stock which he can turn on his lathe is not limited by the Dremel chuck.   His lathe has the ability to turn any stock dimension up to the throat height (i.e. about 1/2 the diameter of the Dremel motor unit).    That could probably be increased with the addition of some spacers.
    May 2003
Posted by jtilley on Wednesday, January 11, 2006 12:31 PM
Sounds like he modified the Dremel chuck.  A good idea - and the tool obviously can do far more than taper spars.
A variation on Vapochilled's idea also would work - and take practically no time to set up.  Drill a hole in a piece of plywood (or styrene, or whatever) and make your own steadyrest to hold the end of the dowel.  For that matter, you could drive a nail through the board in question and make your own dead center.  Clamp it to the workbench edge at the appropriate distance from the drill and it should work fine.
The bottom line in all this is that tapering dowels to make spars doesn't need to be a big deal.  Get some good, hard, smooth, straight-grained dowel stock (birch, maple, and cherry are all good -but avoid oak), and buy enough of it to let yourself make some mistakes.  Then have at it.  The worst that can happen is that you'll melt your fingers.
Posted by Anonymous on Wednesday, January 11, 2006 2:16 PM
AND WEAR SAFETY SPECS!!!
Posted by Anonymous on Wednesday, January 11, 2006 7:20 PM
There we have it again.
I knew I could count on you all to provide great answers to those unsolved mysteries. I like the single tool idea. I'm going to get myself a dremel. But will ahve to wait a bit. That is OK I will do the work on my SM by hand for now. It ahs taken me this long to get to this stage of building her, that a little extra time to do the masts and yards is not going to kill me. Now, when I get to this stage with Pamir, Oh,boy....
Thanks again all,
Robert
Posted by Anonymous on Wednesday, January 11, 2006 7:36 PM
I have just noticed something. I have an annoying habit of signing all of my posts as if they are letters or e-mails. I will do my best to stop this behavior.Blush [:I]
Robert
Posted by Anonymous on Monday, January 16, 2006 8:57 AM
You seem properly dedicated to this build!  It has been suggested numerous times by numerous authorities (but not among these posts) that you may find it easier to start (this is counter-intuitive) with a square section piece rather than a dowel.  Method: cut the corners to an octagon, then again to a sixteen-sided "pencil" then round from the main deck upward.  This gives you accurate shaping at the foot and tenon and gives purchase for the wedges that fix the mast as it enters the partners on the deck.  Imagine trying to "back into" these shapes starting with a dowel.  My experience is that with small scale the mast can probably be round all the way to the step.  Not necessarily authentic in every case but easier.  With a larger scale the squared-octagon-sixteen-side method presents a much finer appearance.  Not as difficult as it sounds. The lathe could certainly be used to good effect in the final rounding and tapering toward the truck or cap (the SM's mast was probably two parts, upper and lower, on the main and one pole on the fore- and mizzen-mast.)
Best,
Ron
