I've been toiling away at my Revell 1/72 U-Boat. Got really familiar with the grinding accessories on the ol' Dremel clearing out every little hole in the hull- this really
is a submarine with screen doors! I'm adding the Yankee Modelworks pressure hull. It's a nice casting, but not without it's flaws. Seen from above, the piping on the cnter and rear sections does not match up! It's not quite the "drop-in fit" that's advertised- I had to do a fair amount of guesswork to position it, and then lots of foamcore board to cover the gaps at the sides. Gobs of hot-glue stuck the filler in.
Because the torpedo tube areas are very open to venting I built up a forward lower hull from a bunch of, well, crap. Solder, the end of a long butane lighter and bits from its workings, as well as various bits of stock styrene tubing. Here's a shot it in all it's majesty...
In the gloomy depths of the hull I'm hoping it will look convincing.
Here's the aft tube, meticulously crafted from more detritus, including part of an allergy spray dispenser. How many of you, comrades, can't throw odd bits away? Show of hands, please! :lol:
I extended the hatches and the 88mm gunmount up to the deck using the same true-to-scale dedication... still have to dope some structure in for the base of the fighting room in the conning tower. Time to cannibalize another old remote control!
I set up an ersatz rounter with my Dremel locked low in it's drill press to gring\d away at the underside of the deck- with pretty good results. Only a few tragedies to clean up, and the result is a see-through grillwork.
Here's the whole thing temporarily clamped together and sitting in it's cradle- quite dramatic in the failing light of Saturday afternoon, dontcha think? Tomorrow (hopefully) I'll spray the "unseen" portions of the inside black, start noodling color on the torpedo tube sections, and glue this dawg together. Then it'll be time to paint the pressure hull and get serious with the photoetch parts of the deck...
