Correct CVN 65 Length?
Posted by Anonymous on Saturday, January 28, 2006 9:33 PM
I have a really detailed book (published in 2004) that has says the CVN 65 current length is 1,123ft and the beam is 133ft. I have read other accounts of the dimensions of the ship, but these measurement were confirmed by a navel office actually on the ship. I know these are correct, but why is their so much discrepency out their regarding this?
    August 2005
Posted by EdGrune on Sunday, January 29, 2006 9:22 AM
Enter Pet Peeve Mode
It is NAVAL.   Navel is your belly button.   You have an office in your belly button?
Same with Hangar/Hanger
Exit Pet Peeve Mode
There are different methods of measuring a ship's length.   The three most often used are Length Overall (LOA),  Waterline Length (LWL), and Length Between Perpendiculars (LP or LPP).
LOA accounts for things on a ship which hang over the bow and stern (as a flight deck).   LWL is the length of the ship's waterline at standard displacement.    LP is a measurement which is more difficult to describe - it is measured from the first vertical frame of the stem to typically the rudder stock.
Each measurement has its own reasons in naval architecture.   Whenever you read a ship's measurement you should be aware of the units which are being reported.  Any information which you get which does not provide this information should be suspect.   If the information is not provided, ask.  If they cannot answer satisfactorily then reject their information
Posted by Umi_Ryuzuki on Monday, January 30, 2006 2:27 AM
Online, I like to use Navsource,
http://www.navsource.org/archives/02/65.htm
or Global Security as quick referances
http://www.globalsecurity.org/military/systems/ship/index.html
Other than that, I prefer "Conway's All the world's Fighting Ships"
However, I don't have the book that covers ships after 1946. Most of my building and referance requirments are met by the 1922-1946 version.
Nyow / =^o^= Other Models and Miniatures http://mysite.verizon.net/res1tf1s/
