I assume that you are talking about the square bridge windows as opposed to the portholes. Opening bridge windows is a matter of personal preference. Often PE framing is applied and some black ink or paint is filled into the space. It is your choice if you choose to do so.
You can use Future floor polish to attach the PE to the clear plastic. It has the extra benefit of helping to make the clear - more clear. You may also apply the clear with Future or Elmers glue. Paint the PE before applying, bend to shape, and touch up any paint nicks.
The problem you may have when using clear plastic will be when you overcoat with the clear flat to kill the shine of the CA used to apply the PE.
