Conventional light globes can be problemmatic. They generate heat
and can blow quite easily especially if confined - they can even melt
plastic. They're cheap and easy to wire up and use but they will
inevitably blow one day and if they do it will probably be impossible
to replace them without major surgery. I built the Bandai Star
Trek Enterprise a couple of years ago and last year when I came to
display it at a show
all the six light globes had blown
- apparently got too hot through being on for too long.
Fortunately that model was easily dismantled so I replaced them all
with blue and white LEDs (the result was fantastic!!).
I recommend Electroluminescent (EL) sheet which the Sci-Fi modellers
use for space ships ( http://www.starshipmodeler.com/olb/olb_sm_vgr.cfm
), it's also used to light buildings by model railway
enthusiasts. Another possibility is Cold Cathode Flourescent
tubes. Both these options run cool, give a realistically coloured
light and are not
too expensive. Another option is white LEDs.
If you Google these products you'll find suppliers in your
country. There are lots of lighting articles on SF modelling
sites and the principles apply to ships just as well.
EL sheet and CCFL tubes both run on about 12V, the only drawback is
that each needs an 'inverter', an electronic circuit mounted on a small
board (typically 1/2" by 3") which also needs to be accomodated in the
model.
LEDs tend to be focussed like flashlights so it's a bit more difficult
to distribute their light. Using reflective surfaces it can be
done though. Unlike light bulbs you have to watch their polarity
too i.e. + and -. The best things about them are they only need a
single resistor in circuit for each one (chosen to match the voltage
selected e.g. 480ohm for 12V), they don't get hot, they're cheap and
they'll last practically forever - or at least as long as your
model. It is possible and feasible to use batteries with them as
their power consumption is incredibly low.
That's just a general overview off the top of my head, others may know
more and have better advice. If I spot any sites of interest I'll
pass them on.
Michael
