Two sides of a ship model?
Posted by rcboater on Friday, February 17, 2006 9:45 PM
I've been thinking...
Has anyone built a ship model with two different sides?  For example, you could build a model with the starboard side painted in camouflage, while the port side  is painted in peacetime gray.  If you're displaying the model on a mantle or shelf, only one side would be seen at a time.   Another option might be to only weather one side-- have a clean and dirty side....
I  have a special shelf reserved for a big ship model in my den- part of the back wall.  I started thinking about how I could speed up the actual completion  a bit if didn't put as much work into the unseen  side of the model.  One of the ideas I was considereing was building the big 1/350 Titanic, using fiber optics to light the portholes. If Idid that, there'd be no point in doing the back side.....
Just wondering......
Webmaster, Marine Modelers Club of New England
www.marinemodelers.org
    February 2006
Posted by RickF on Saturday, February 18, 2006 7:07 AM
You could also stick a big mirror behind the shelf and push the half-model up against it.
Rick
    January 2003
  • From: Upper left side of the lower Penninsula of Mich
Posted by dkmacin on Saturday, February 18, 2006 7:25 AM
Check out your back issues of FSM, this was done though not the exact way you describe.
The FSM version had a usual static display on one side and the "at anchor" on the other. Really a neat idea.
Yours too sounds pretty neat, a USS Arizona pre war and at Dec 7, or such.
Don
I know it's only rock and roll, but I like it.
    August 2005
Posted by EdGrune on Saturday, February 18, 2006 8:12 AM
Link to article here
http://www.finescale.com/fsm/objects/pdf/just%20add%20water.pdf
Or go up the main page to Articles and down to ships
    December 2003
Posted by scottrc on Saturday, February 18, 2006 10:44 AM
Many years ago, at a show in Seattle, I saw a model of the Queen Mary that had one side painted and fitted out in her peace time attire and the other side painted and fitted out in her war time arragement.
It was quit interesting as I recall.
Scott
    May 2003
Posted by jtilley on Monday, February 20, 2006 12:17 PM
In my opinion there's nothing wrong whatever with making the sides of a ship model different - if the subject matter lends itself to that approach.
The museum where I used to work has an enormous model, dating from the 1930s, of an ocean liner representing the sister ships President Hoover and President Coolidge.  The model, if I remember correctly, was built while the actual ships were under construction.  I'm sure there were minor differences between them in real life, but the model had the name President Hoover on one side of the bow and President Coolidge on the other.  Behind the scenes we called it the Hoolidge.
I have a vague recollection that Airfix originally issued its Concord kit with the markings of two different airlines, one on each side.  Why not?
Posted by ABARNE on Monday, February 20, 2006 6:16 PM
 rcboater wrote:
... you could build a model with the starboard side painted in camouflage, while the port side  is painted in peacetime gray.  If you're displaying the model on a mantle or shelf, only one side would be seen at a time.
I would think that mostly you would end up with an odd looking effect.  Camo will wrap on the superstructure, and stacks such that you would have a dividing line down the centerline.  Don't forget the decks.  A camoflaged ship will have blue of camo'ed decks whereas the peacetime ship would have wood or gray decks, again leaving you with the odd centerline demarcation.  The only way you would not see these effects would be to view from a direct broadside with your eye at the height of the main deck.  You probably would have different fits as well.  For example, a WWII Iowa had a zillion 20mm guns, wheras the postwar Iowas quickly lost them.  You also have different mast arrangements, which occur on the centerline, so you have to make a hard choice as to what fit you're portraying versus doing the wartime version on one side and the peacetime on the other side.
Still, if one were viewing it as a more instructional sort of a build, like a cutaway for example, there's no reason why you can't do it.  I would think though in that case the most effective display would be some sort of walk around type where you could look at one side and then the other.
    March 2005
Posted by mfsob on Tuesday, February 21, 2006 11:40 AM
I was thinking about doing something similar with a Victory or Liberty cargo ship, since some of them had quite colorful "house" colors postwar compared to the overall pick-your-shade-of gray during WW II. The only thing giving me pause is how it would look from overhead, with a dividing line right down the middle. But heck, in 1/700 scale, that might actually look normal.
