Best way to paint the Hornet 1/700 scale paint job Doolittle Raid
Posted by Anonymous on Saturday, February 18, 2006 5:25 PM
What is the best way to paint the Hornet, used on the Doolittle Raid. Do you use mask, by hand,  air brushing ? Any information will be help-ful, before I mess it up good.   Thank you, Tony
    July 2005
Posted by warhorse3 on Sunday, February 19, 2006 8:36 AM
The most accurate and probbably the easiest would be to make template masks to cover the lighter haze gray on the island and the ocean gray on the hull. I did mine the hard way (freehand with a brush) using the Mk 1 eyeball lining up reference points on the ship. Next time I,ll mask. If memory serves, there are a couple of articles in FSM showing how to make the masks using your printer or a copier. I hope this helps .
Regards, Bill
Posted by Anonymous on Sunday, February 19, 2006 9:14 AM
Thank you for your help......... Tony
