Greylipps wrote: |
Ok, Got the idea. The Super Yamato had only 2 barrels per turret, not the triple. So, wouldn't it make it a little over 3,000 tons? So, the ship would only be slightly larger, in length and width.
Am I on the right track?
Yes. The Japanese had plans to re-arm the Yamatos with 20" guns in twin turrets within 5 years of their commissioning. So Yamato hull can definitely accommodate 20" guns.
The 18" guns had been a great secret. The Japanese expected that, when the truth about the Yamato's size and guns finally comes out, the US would be well along on construction of Iowas and Montanas. Too late to make fundamental changes to the armor and barbettes of these ships. The most US could do would be to possibly swap out Iowa and Montana's 16" triples for 18" twins. If this were to happen, the Japanese would immediately respond by replacing Yamato's 18" triples with 20" twins, knowing the US ships, with their barbettes originally designed for 16" triples, can never accommodate a 20" twin. Thus they can garranty that Yamato class would continue to enjoy qualitative superiority for another 4-5 years.
But regarding the actual follow-on to Yamatos, they would probably be about the same size as the yamatos. The Yamatos were too big for existing Japanese naval facilities, so 4-5 new docks were to be built for them. Some of these never started because of the war. But these new docks were only good for ships marginally larger then the Yamatos. So it seems the japanese didn't really entertain the notion of ships much larger than Yamatos.
Any follow-on to the Yamato would probably have ditched the 6" triples superfiring over the front and rear main turrets. These turrets were a major loop hole in Yamato's massive magazine armor, and was much critisized inside the IJN. In any case, Yamato's inefficient mixed secondary armament, with separate anti-surface and anti-air batteries, would probably ave been replaced by a uniform caliber, dual purpose secondary battery. The 6" anti-surface guns would probably be gone altogether. The 5"/40 AA guns would probably have been replaced with far superior 3.9"/65 dual purpose guns.
If we accept that follow-on Yamatos would not have 6" turrets taking up valuable centerline space, then the superstructure layout could have been made much more relaxed, and less cramped. It should also free-up room to for a better arrangement of secondary guns on the beam. Yamato's superstructure was so camped that 3 5" twin turrets is all that could be accommodated in a roll. Yamato follow-on could probably find space for a more relaxed arrangement. Possible 4 on one tier and 3 on another.
Contrary to popular history, Japanese had radars under development since before 1940, and a Yamato follow-on would almost certainly be designed from the on-set to carry radar.
