Need some help with artifact identification
    March 2005
Posted by mfsob on Saturday, March 18, 2006 11:02 AM
I had the priveledge last year of doing an archaelogical dig at College Park, Md., the oldest continuously operating airport in the world. Among the many little "bits" of stuff we found were some curious things that look like short pieces of non-metallic wire encased in a carbon or graphite. Click on the link for a photo:
 http://home.earthlink.net/~mffowler/cpartifact.jpg
The current technical name for these, of which we found more than 20, is "thingies." Although I am reasonably sure they are not nautical in origin, I'm hoping that someone familiar with 1900-1930s technology can help us narrow that down a bit!
    December 2005
Posted by onyxman on Saturday, March 18, 2006 11:37 AM
I have no idea, but it looks like some kind of spark plug.
    June 2004
Posted by clfesmire on Sunday, March 19, 2006 11:20 AM
My first inclination is thinking they are some type of insulator for electrical wiring. I'm not familiar with the shape but often, especially in the time period you describe, non-metallic objects were encased in carbon for that purpose. Interesting find, hope you learn more.
Chester
    January 2003
Posted by Jeff Herne on Monday, March 20, 2006 9:33 AM
Onyxman has it. Very early combustion engines didn't have spark plugs as we know them today. These plugs would be inserted into the engine block opening and the spark would result when the piston itself got close enough to the core of wires to arc across. Usually, it was just a hole, and a metal forked clip held the plug down, hence the term "plug". They were generally connected to a crude magneto usually driven by gear or friction drive directly from the crank.
Typically, these plugs didn't last long, which is why you'll find them all over the place and in large quantities. As the compressions in engines rose, neither the "plug" method or the materials used could withstand the pressures, so the spark plug as we know it today, a threaded metal rod encased in ceramic, came along. We have early Curtiss examples dating back to 1909.
I'd place the time frame sometime between 1905 and 1910. We have an example of an early Boland engine dated 1908 that has missing plugs. I actually fabricated a pair that look very similar to this, from turned acrylic rod, to fit the engine. The openings are not threaded.
Hope that helps,
Jeff
(Former Director of the NJ Aviation Hall of Fame and Museum)
    March 2005
Posted by mfsob on Monday, March 20, 2006 10:50 AM
Thumbs Up [tup] to onxyman and Jeff! I'll forward these on to the guy doing the actual report. Being able to put a name to them is a LOT better than lumping them in with the other "unidentified thingies."
