Here's a few photos of my 1/120 scale "Black Falcon" brigantine built
from the SMER kit, a re-issue of a 1950s Aurora mould. So far I have
completed and painted the hull - next stage will be to fit the masts,
cannons, other fittings, and rigging.
The first image is linked, the other 3 need to be clicked on to view them (saves page loading time for 56k users like me!)
http://www.users.globalnet.co.uk/~pinniger/models/ship/bfalcon2.jpg
http://www.users.globalnet.co.uk/~pinniger/models/ship/bfalcon3.jpg
http://www.users.globalnet.co.uk/~pinniger/models/ship/bfalcon4.jpg
I was advised not to buy this kit by jtilley (definitely this forum's
sailing ship expert), who recommended various Lindberg and Pyro kits
instead - see below for why I ignored expert advice and still ended up
buying this crude + outdated kit.
Firstly, I know very little about historic sailing ships, my main
modelling interests are WW2 and earlier aircraft, tanks and warships. I
decided to build this for three main reasons - thirdly, I have two
large Revell ship models, the Constitution and Cutty Sark (the former
an eBay bargain, the latter a gift) which I would like to build in the
fairly near future, but was reluctant to tackle a large, complex model
of a subject I've never attempted before.
I also thought a sailing ship might be an interesting challenge to
build + paint - painting the largely wooden hull and fittings would
require quite different skills to painting a 20th century steel warship.
Basically, this is the cheapest kit you can buy in in the UK or Europe
of a sailing warship in a reasonably large scale. Its RRP is £3.99 (a
bit under $10), the only other kits in this price range are assorted
Heller and Airfix "series 1" ships, which apart from being tiny
(usually 1/300 to 1/600 in scale) are normally incredibly crude -
Airfix's "Golden Hind" is the first injection-moulded kit this company
ever produced.
Kits like the Lindberg "Jolly Roger", and the others mentioned above,
are very hard to find on this side of the Atlantic, unless you buy on
eBay from a US seller, which adds significantly to the cost due to
postage.
The "Black Falcon" was apparently Captain Kidd's ship - whether the
model actually represents this ship or not, I have no idea, but from
what I have read the ship is a brig/brigantine or two-masted frigate.
It looks quite similar to the Lindberg "Jolly Roger" kit which is
apparently a French frigate, though it is smaller and has fewer guns.
The only reference photos I have are some of the Mantua wooden kit
(seen here - http://www.woodenmodelships.com/ni-087.shtml ), which is
about the same scale. I'm not sure how accurate a representation of the
ship this is (based on jtilley's recent comments on wooden ship kits!)
but it was all I could find.
Hence instead of "accurising" the kit I concentrated simply on cleaning it up and replacing or refining some of the cruder
parts of the kit. I also removed the Jolly Roger and the Black Falcon
(very crudely moulded in any case) as I wanted the model to represent a
"generic" light naval warship rather than a pirate vessel.
The gun ports were drilled out and I added lower decks (visible through
the skylights). I didn't add the 6 missing cannons, I briefly
considered casting them in white metal but decided against this as I
wanted to keep this project simple and straightforward. The aft
skylight was also drilled out and I removed some of the moulded deck
detail. I also reshaped the bow to match the Mantua model, lowering the
angle of the bowsprit significantly. The bow will need further
modification in order to attach the figurehead.
Much cleaning up of flash, moulding seams, etc. was required on
virtually every part, and the hull had a large number of sink marks
which required a fair bit of putty to fix.
Masts and fittings have also been cleaned up and in some cases reshaped/detailed, these are not fitted or painted yet however.
The model is painted with Tamiya and Revell acrylics, metallic paints
are Citadel/Games Workshop and weathering was done with artist's
acrylics and oil washes. The deck was painted with medium brown then
drybrushed with a lighter greyish-brown, finally given a diluted black
oil wash. Gilding was represented by first painting black, then
drybrushing heavily with a dark, brassy gold colour, next lightly
drybrushing with a brighter gold, and finally retouching the black
around the edges.
It is painted more or less according to the kit instructions, whether
these are accurate or not I'm not sure but they seem to match the
colours described here - http://home.att.net/~ShipModelFAQ/ - fairly
closely. The colour scheme seems more appropriate to a naval craft than
a pirate ship.
More photos when the ship is finished! Apologies for the very long post.
Feedback would be greatly appreciated from anyone with more knowledge
of wooden sailing vessels than me! It looks nice to me so far but for
all I know it could be about as accurate as a Spitfire Mk.1 with a
5-bladed prop, bubble canopy and D-Day markings.
(edit: fixed image links)
