Thanks Scott! I can honestly say that I did NOT enjoy painting these little containers! It seemed that every time I thought I was finished, I found somewhere else to touchup! Thanks again for the compliment.
mfsob wrote: |
I'm still eying the MV Tampa (like I don't have enough unbuilt kits lying around just because it could be painted in such a a rainbow of colors with all the containers. I can't tell from the photo, though - do the containers come as individual units that you stack up yourself, or does the construction you described mean that each "block" of containers has to have the individual container details painted separately?
And what's the LOA on that puppy? I have to be kind of picky on what I build due to space considerations (I have none!). |
Thanks mfsob. The containers come as blocks that you have to assemble with the details molded in as recessed lines delineating each individual container. So there are four walls: two have small squares on them giving the appearance of the conainer ends, and two other walls that have horizontal recessed lines with a couple verticle lines here and there denoting two 20' placed end-to-end in the stack The top piece also has the lines showing the tops of the containers. I had to paint each container seperately, then used a pen to draw inside the recessed lines to bring out the containers.
This kit measures out to 19 1/2 inches long and 3 inches wide. Height, no more than 5-6 inches off the base. Add two inches for the base.
I know what you mean about not having space! With 979 models built, I have run out some time ago!
Powder Monkey wrote: |
Don't sell yourself short. I think they look great!
Thanks Powder Monkey, I appreciate that. I do like the way these turned out. Thank you for the compliment.
kp80 wrote: |
Duke,
Great mix of colors on the boxes, and a good mix of 20 footers and
40 footers. From my observations, a good representation of box size
mix is usually 80% 40's and 20% 20's. Visually, I think you got it
right. There isn't much rigging on a box ship, so I wouldn't be
concerned with lack thereof on your model. Thanks for sharing the pix. |
Thanks Kp! I didn't really have a choice on how to mix them up since each section is a solid block with lines delineating each container. LOL! I did do my best to get a good mix of colors; I checked out online references, and also checked out the San Pedro harbor while I was in the area one day. I saw how they stacked everything and did my best to make the containers look realistic in that respect.
Yann Solo wrote: |
Thanks for the information, I was expecting more from that kit
concerning the level of details. I think you did a good job on these
models. Maybe a little weathering would give a little bit of life to
them but that's just me. Thanks for sharing. |
I was also hoping for more detail, but IMEX makes them pretty simple. Still, they look pretty good on the shelf, and if your skills are better than mine, I'm sure you'll really be able to make this one pop. I wouldn't mind weathering this too, but despite looking at the real thing several times, I
don't know how!
Maybe in the future I'll pull it down again and give it a go.
Meanwhile, for those who are still watching this Thread, here are a few more photos of a couple other projects. One is completed, the other almost finished.
This one is the NedLloyd Rouen. She is a Ro-Ro ship, as seen by the massive ramp on the back. These next two pics show the ramp in the two positions:
And here she is from the bow:
I have only to touch up some paint and then decal this one and she'll be done.
And now I have another cargo/container ship finally out on her shakedown cruise.
Check her out, the MS Toyama:
I hope you like them. Comments are welcome.
